TEMPLATE used to install rear-bumper/valence from OEM body kit.
Old Mar 26, 2003 | 01:57 PM
R rated's Avatar
Default TEMPLATE used to install rear-bumper/valence from OEM body kit.
Search is down,so hopefully someone knows where I can find this template.I bought this part used & the guy who sold it to me couldn't find it.
Knowing where to drill my holes on bumper would be much easier with the templates.
Thanks in advance,DAVE.
Old Mar 26, 2003 | 02:10 PM
98type_r's Avatar
New User
Default Re: TEMPLATE used to install rear-bumper/valence from OEM body kit. (R rated)
i should still have mine somewhere, lemme check when i get home late tonight. will post if i can find anything
Old Mar 26, 2003 | 02:11 PM
hungsteR's Avatar
Default Re: TEMPLATE used to install rear-bumper/valence from OEM body kit. (tie par)
I need to find that also. I installed my rear kit without those two holes.
Old Mar 26, 2003 | 02:50 PM
R rated's Avatar
Default Re: TEMPLATE used to install rear-bumper/valence from OEM body kit. (hungsteR)
Wow,did it stay in place?
Old Mar 26, 2003 | 02:51 PM
hungsteR's Avatar
It stays in place with the two mount holes in the front and the rear onw that you drill into the bumper. It would be more secure with two more holes in the bottom but I lost my template too.
Old Mar 26, 2003 | 03:01 PM
SurferX's Avatar
I installed the OEM kit on my LS and I don't believe there was a template.
I remember it coming with double sided sticky dots that I was to put over the hole on the rear piece. After placing the rear piece up against the bumper as if it were installed, the sticker stuck to the bumper in the place that I was going to be drilling. It was about 3 years ago but that's how I remember doing it at least. I don't recall any sort of template.
Old Mar 26, 2003 | 03:27 PM
Veritas-Aequitas's Avatar
Grumpy Old Man
Default Re: TEMPLATE used to install rear-bumper/valence from OEM body kit. (SurferX)
The bodyshop that did mine put two screws through it
I was pissed but you get over that kind of stuff after a few beers
Old Mar 26, 2003 | 03:41 PM
hungsteR's Avatar
There is a template so you can figure out were to drill the two holes for the bottom brackets.
Old Mar 26, 2003 | 04:31 PM
Tommy_Gunns's Avatar
Can't you line it up and mark with the holes are?
Use vaseline to make the marks if you are unable to get a pen/pencil to mark it.
Old Mar 26, 2003 | 04:40 PM
SurferX's Avatar
Like I said you do that by using the double sided stickers that would have come with the kit if you got it from the dealer. If I can find my old install instructions the dealer gave me I'll post them.
Old Mar 26, 2003 | 05:09 PM
Hairy Gorilla's Avatar
Someone on H-T emailed me the template. I have it in my email. PM me w/ your email and I can forward the template to you...
Old Mar 26, 2003 | 05:10 PM
hungsteR's Avatar
Default Re: TEMPLATE used to install rear-bumper/valence from OEM body kit. (Tim Maryak)
Email it to me at hung8489@yahoo.com and I will host it.
Old Mar 26, 2003 | 05:45 PM
A big thanks to stinkytofu. Hope these work. I assume the template is 1 to 1.
Old Mar 26, 2003 | 08:39 PM
R rated's Avatar
Thanks Tim & stinkytofu,that really helped.
LatinEM2
Jan 24, 2006 06:28 AM
boost fed ls
May 3, 2004 05:36 PM
UnionCity LS
Mar 5, 2004 07:41 PM
(__________)
Sep 17, 2002 12:44 PM
yellowbuffalo
Jun 13, 2002 06:45 AM
