who has a GSR cluster??? i can't get the speedo or fuel to work??
Old Mar 26, 2003 | 12:52 PM
dingusjt's Avatar
Default who has a GSR cluster??? i can't get the speedo or fuel to work??
damn i got everything hooked up as per the instructions on http://www.angelfire.com/dc/oregonimport/gsr1.html
and my speedo nor my fuel gauge is working..can anyone tell me what wires to hookup or have any better directions?
Old Mar 26, 2003 | 06:03 PM
^Sammy]!.'s Avatar
From: 9/11/01 WTC Never Forget, United States Of America
Default Re: who has a GSR cluster??? i can't get the speedo or fuel to work?? (dingusjt)
Dingusjt..........use this diagram this is the best one i used it myself.
As for the speedo mines isnt working yet either but i was told a ground needs to be added to the right hand (b side) for it to work............im gonna try it this weekend i will let you know how it goes okay.
Here's a diagram pin side Integra cluster 96 I think. However I know between 94-97, and 98+ the fuel gauge and other warning lights are in different locations. So I think if your cluster is 98+, switch b1 and b3 around on this diagram. Left to Right.
B1 - Fuel Gauge
B2 - Door Open
B3 - Blank
B4 - Fuel low level sensor
B5 - Blank
B6 - VSS
B7 - Hatch Indicator
B8 - Seat Belt Reminder
B9 - Dash light brightness controller
B10 - Gauge lights
B11 - Ignition Black/Yellow
B12 - Blank
B13 - Left turn signal
B14 - Right turn signal
B15 - High Beam Indicator
B16 - Parking Brake light
D1 - Hazards
D2 - Maintenance
D3 - Blank
D4 - Switched power to cluster
D5 - Cruise Control
D6 - Ground
D7 - ECT
D8 - Blank
D9 - Alternator
D10 - Blank
D11 - Oil Pressure
D12 - Malfunction indicator
D13 - Tach signal
thefiztec
Aug 7, 2013 04:29 PM
714DC4
11
Apr 6, 2008 10:11 AM
fubulous
Apr 22, 2004 05:56 AM
dingusjt
Mar 30, 2003 04:30 AM
juicy.koreans.suck
Nov 12, 2002 05:48 PM
