215/35/18 vs. 225/40/18????
Old Mar 26, 2003 | 12:13 PM
SleekBlkPrelude's Avatar
Default 215/35/18 vs. 225/40/18????
hey guys... the rims i ordered are on backorder and still at the port cuz of the war, i still have time to change it ffrom 215/35/18 to 225/40/18....
what is the difference??? besides the price???
i heard 215's are thinner so i feel bumps harder and greater chance of denting rims... but then i heard 225 are so damn thick that it will make my ride ugly... i dunno... HELP!!!
Old Mar 26, 2003 | 12:30 PM
satan_srv's Avatar
Default Re: 215/35/18 vs. 225/40/18???? (SleekBlkPrelude)
you won't fit 225 18's, no way
Old Mar 26, 2003 | 12:40 PM
Default Re: 215/35/18 vs. 225/40/18???? (satan_srv)
umean that on my 2001 prelude 225 18" wont fit?
btw: my car is dropped 2 inches on koni/gc
Old Mar 26, 2003 | 12:44 PM
satan_srv's Avatar
that's what I am thinking, but I could be wrong...depends on your rim offset I guess.
Old Mar 26, 2003 | 12:54 PM
what is offset???
Old Mar 26, 2003 | 01:32 PM
Volcom's Avatar
what is offset???
You're in trouble. Offset is basically how close or far the wheel sits on the car. A 45+ mm offset will set the wheels 5mm closer inside the car than compared to a 40+mm offset. You might check on what kind of offset those wheels have first before you get them
Old Mar 26, 2003 | 02:37 PM
Default Re: 215/35/18 vs. 225/40/18???? (Volcom)
i don't really mind about the offset... i saw the rims i'm getting on the same car as mine, 5th gen... it looks perfect(the offset)
but i really want to know what a 225 will be like on my car isntead of the 215...
Old Mar 26, 2003 | 03:32 PM
Sticky Tires's Avatar
* B A N N E D *
with 225 and a 2 inch drop you might have rubbing issues depending on your offset. if it's a 48+ offset, you should have minimal rubbing issues. (4+ people in your car, tight turns...etc) i've read that some rub and some don't on 225. some even went 235 but like i said it depends on your offset. i say go with 215 if you don't want any hassles or issues with rubbing. they say the wider the better for handling but it's all on you. btw, whats the offset for the rims you getting?
p.s. you might need to roll your fenders w/ 225
Old Mar 26, 2003 | 06:13 PM
Default Re: 215/35/18 vs. 225/40/18???? (Sticky Tires)
Old Mar 26, 2003 | 06:31 PM
Que_Lude's Avatar
225 will be a little bit heaver.... may not want that with a car that is already heavy. The 215/35 is a reallllly low profile tire... you will feel every single bump in the road. (The 40 is almost the same)
Old Mar 26, 2003 | 07:10 PM
Default Re: 215/35/18 vs. 225/40/18???? (Que_Lude)
yea, this is what i wanted to know... haha.. thanks Que_Lude...
but one more thing... what are the chances of the rims being dented in because the 215's are more thinner??? does having the 225 reduce the risk??? a lot of people have told me that i should just stick to the 215...
Old Mar 26, 2003 | 08:56 PM
H22pwrdhatch's Girl's Avatar
ok, well from personal experience......i have a rd 99 lude with 225/40/18 and a 2.5 inch drop and i have no problems....i love mine
Old Mar 26, 2003 | 09:20 PM
Default Re: 215/35/18 vs. 225/40/18???? (PreludePrincess)
So what's the diff between that and 215/35/18? 225/40/18 costs more... do u have a pic? so that i can compare the size/look??? thanks
btw: u have camber problems? thanks...
Old Mar 26, 2003 | 09:58 PM
99_SH's Avatar
225 is wider than 215. If you have poor wheel offset get the 215, but not in 35 series, its way too thin.
BTW, I have 222/35 on my 18x8 wheels(GEN5). They do fit, no rubbing whatsoever
edit: wheel/tire size have nothing to do with camber
[Modified by 99_SH, 7:00 AM 3/27/2003]
Old Mar 26, 2003 | 09:59 PM
Volcom's Avatar
those tires sizes aren't even close to each other. In fact, they are 4.9% off from each other. Here's the scoop:
215/35/18
sidewall 3.0 in
diameter 23.9 inches
225/40/18
sidewall 3.5 inches
diameter 25.1 inches
To be closer together, it sounds like you'll either need a 215/35/18 or a 225/35/18. At least those are only 1.2% off from each other, not 4.9% or 1.2 inches of diameter.
Old Mar 27, 2003 | 05:15 AM
rjr162's Avatar
i was about to say the same thing..
215/35/18 would be more like a 225/33/18 (which obviously they don't make)....
Accord1234
Jan 31, 2008 02:50 PM
cappelhans
10
Jan 23, 2006 06:32 AM
Blazeone
Jun 18, 2004 05:00 PM
Sticky Tires
Nov 1, 2002 07:36 PM
fluke702
Nov 30, 2001 06:31 PM
