type r header on ef
Old Mar 26, 2003 | 06:05 AM
cornholioEK's Avatar
Default type r header on ef
how well will a jdm oem 4-1 header fit on a cr-x with a b16? do you need to modify the crossmember?
Old Mar 26, 2003 | 06:07 AM
EP3_05's Avatar
Default Re: type r header on ef (DOHCvtecCR-X)
You will have to notch the front crossmember considerably or buy an aftermarket unit that has clearance for a 4-1 header. As well the ground clearance with the 4-1 header on a b16 in an ef is going to be bad and therefore the header will be prone to damage from scraping and bumps from the road below.
Old Mar 26, 2003 | 08:40 AM
All Motor Rex's Avatar
Default Re: type r header on ef (91civic)
Yep. I hope your car isn't too low, and yes you will need to modify the cross member.
Old Mar 26, 2003 | 09:12 AM
Default Re: type r header on ef (All Motor Rex)
damnit. well im just going to go with an AN-R header then. i'm going to switch to a b18c5 set up soon. i can't wait.
Old Mar 26, 2003 | 11:28 AM
Charlie Moua's Avatar
thats what i want to get too but i need the proff that they are worth it. I can't wait till they get some dyno charts/comparisson out!
Old Mar 26, 2003 | 01:05 PM
Default Re: type r header on ef (Charlie Moua)
a big reason why im going to the b18c5 is that i need a new transmission and i want a newer motor. the b18c5 swaps come with a LSD tranny which is also a plus and they have less miles and are newer.
Old Mar 26, 2003 | 05:19 PM
Ruby Civic's Avatar
quaife is a great lsd and will go into earlier b series trannies....but incr. displ. is nice tho
Old Mar 26, 2003 | 05:22 PM
bryant's Avatar
Have fun swithing to hydro.
Old Mar 26, 2003 | 05:43 PM
altoid's Avatar
Default Re: type r header on ef (Bryant)
hasport's got you covered dawg
Old Mar 26, 2003 | 05:46 PM
bryant's Avatar
Default Re: type r header on ef (altoid)
if they ever finally releace it that is.
Old Mar 26, 2003 | 05:58 PM
riceboyEFsi's Avatar
make or buy a skidplate , btw forget hydro tranny in a ef cable b16 w/ a quaife or phantom is the only way 2 go
Old Mar 26, 2003 | 06:00 PM
also u got a nice setup screw the b18c5 its time to find a Ls block and start buildin that ish up , u already basically have everything u need build the ls motor use the b16 tranny and swap the head ,manifold and fuel system over thats what i would do alot cheaper also
[Modified by riceboyEFsi, 12:02 AM 3/27/2003]
Old Mar 26, 2003 | 06:16 PM
Default Re: type r header on ef (riceboyEFsi)
im also goin for reliability. i dont like ls/vtec swaps much. type r motor will be bad *** in my cr-x
Old Mar 26, 2003 | 07:43 PM
AdamBOMB_STi's Avatar
get a dc 4-2-1 1-piece header cause a 4-1 will scrap.
Old Mar 26, 2003 | 08:01 PM
I guess, a typer r swap is gonna cost ya though . Your payin 4 a tranny u cant use , a ecu u cant use . Im running a b18c5 now im happy w/ it but i really miss my ls/vtec. As stated b4 if u build it right it will be reliable. U already have all good parts on your b16 build up an ls and swap all that ish over . Just my 2 cents
Old Mar 26, 2003 | 08:13 PM
ScottEK's Avatar
Default Re: type r header on ef (kwik_B16)
Very true, if your car is lowered at all with the DC 4-1 have fun, I'm very glad I sold mine before anything happened.
Old Mar 27, 2003 | 04:20 AM
what are you talking about? i can use the tranny AND the ecu. im switching COMPLETELY over to a b18c5 setup, which means im switching to hydro, and im putting in a USDM type r guage cluster and i'm going to put spoon cam gears and a hondata system on the set up when i get it put in as well. its going to be bad ***
Old Mar 27, 2003 | 08:15 AM
unstopabledj's Avatar
yeah but your also gonna have to get the cable to hydro conversion kit from hasport which is gonna cost you 200-300? correct me if im wrong, and also the ecu, your going to have to get the obd0 to obd1 harness which is about 175?, and about that ITR gauge cluster..rewiring and the VSS and some other **** is involved that you have to use..man its not worth it, but if you have all that time and if you "THINK" you can do it go ahead..
Old Mar 27, 2003 | 12:43 PM
Default Re: type r header on ef (unstopabledj)
well i HAVE thought about this for a while. an extra couple hunded bucks dont mean **** to me. i like to get the best and get everything i need and do it right unlike most people that are afraid to spend money. i dont care, its just money. and the guage cluster, i have info on it already and the shop that works on my car is going to do all that
Old Mar 27, 2003 | 01:18 PM
alright well sounds like you got it all planned out and a whole lot of money saved up, not a lot of people have money like you man (ME) so thats why i was just saying..good luck and hope to hear from you soon
Old Mar 27, 2003 | 04:27 PM
Eggman's Avatar
Default Re: type r header on ef (beta13)
...or a 96-97 JDM 4-2-1 ITR header. Still has a 2.5 collector and doesn't hang as low as the 4-1. Great clearance for an EF/ED. mine.
Old Mar 27, 2003 | 04:52 PM
i wouldnt do that 2 to much extra work , the hondata would be nice but unnessesary . Cable b16 tranny w/ a aftermarket lsd is the way to go, get a non obd pr3 get it reprogramed , run a vafc and some slicks your goin 12's . Also if a ls/vtec is out of the question how about building a gsr shortblock and slappin your b16 head on it . It would be the same if not better as a b18c5. Imjust tryin to help ya go faster 4 less $$$$
Old Mar 27, 2003 | 06:48 PM
thanks.
Old Mar 27, 2003 | 06:51 PM
ok - im going to be open minded
heres the thing- my tranny's 3rd gear grinds when i race. how costly would that be to fix, or is it cheaper to get a new one. i also want LSD.
if i DO spend my money on my gen 1 b16, will it be reliable enough to last a while (like YEARS) or will i blow it. next month i'll have like 2000-2500 saved up for my car. what all could i get to make my current set up bad ***?
Old Mar 28, 2003 | 04:05 AM
Ruby Civic's Avatar
i am right now working on the definite answer to replacing 3rd gear and synchronizer set in s1 tranny with 91 integra ls bits....won't be too cheap but slip in that quaife at the same time
70stunt
Welding / Fabrication
19
Nov 3, 2010 05:43 PM
SolAssassin
22
Jul 21, 2009 03:52 PM
10krpmek
Jan 18, 2006 02:10 AM
EG_93Civic
Feb 3, 2003 05:44 PM
Rydaddy
Oct 28, 2002 09:21 AM
