integra suspension on a crx
Old Mar 26, 2003 | 05:43 AM
civicmark's Avatar
Default integra suspension on a crx
ok, so if any of you have heard about the curbed crx i picked up(bend trailing arms, broken radious rods, bent lcas), i'm also going to be getting an integra that was hit in the rear (for that good old b18a baby) and my Q was, can i change over the entire suspension set up from the teg onto the crx?
it's a 91 dx crx, and i can get a 91-93 teg, depending on what will fit best
thanks
Old Mar 26, 2003 | 05:45 AM
CRX Si's Avatar
Default Re: integra suspension on a crx (civicmark)
from what i hear the rear should be ok but dont use the teg setup on the front... I am not sure on when the teggy got its make over but I think that 91-93 are the same... If the Teg was a 4 wheel disk that would be an added bonus...
Old Mar 26, 2003 | 06:03 AM
civicmark's Avatar
Default Re: integra suspension on a crx (CRX Si)
what makes the front bad?
[Modified by civicmark, 2:34 AM 3/27/2003]
Old Mar 26, 2003 | 08:59 AM
4potnick's Avatar
front integra suspension will give you horrible wear on tires because of camber i believe.
Old Mar 26, 2003 | 09:11 AM
civicmark's Avatar
Default Re: integra suspension on a crx (4potnick)
can a camber kit cant do enough to correct this?
Old Mar 26, 2003 | 02:08 PM
CRX Si's Avatar
the teg fronts are too long and dont have enough room to travle... causing bad turning...
Old Mar 26, 2003 | 02:28 PM
mbsi's Avatar
I know the suspension from a teg fits the rear of your car for sure, traling arms and all, not sure about the front..
Old Mar 26, 2003 | 03:36 PM
pokemon's Avatar
Default Re: integra suspension on a crx (mbsi)
I have done a swap on integra front brakes on a CRX HF and it doesn't seem to have a problem. The brakes were from a 90 teg non-ABS. Going to do the rear soon...peaCe
Old Mar 26, 2003 | 03:46 PM
slow hatch's Avatar
Default Re: integra suspension on a crx (pokemon)
On my hatchback, I could only use the spindle arm w/ the front brakes, i couldn't use all the control arms and stuff, but the brakes were a big plus. You can defintly use the back end stuff(brakes, trailing arm.)
Old Mar 26, 2003 | 07:13 PM
eraser's Avatar
no matter what u do to the front it wont align right and youll **** up your camber.......do it right and get the RIGHT parts for your car
Old Mar 26, 2003 | 07:45 PM
ViperRedCRX's Avatar
Default Re: integra suspension on a crx (eraser)
got teg spindles, calipers, and rotors on my 88 si. used the crx uca, and lca. aligned perfect, and sitting at 1 degree neg camber (perfect). have no clue what you people are talking about. but have had mine checked a few times, and everytime it has come up the same. i've heard this before, and i think it's a crock. mine stops 100x better, and the alignment/camber is fine.....
Old Mar 27, 2003 | 08:40 AM
nautica_t's Avatar
Default Re: integra suspension on a crx (ViperRedCRX)
hey viperredcrx, can you tell me what year you used the uca and lca from the teg from?
i need to get my car to stop, my stock discs and drums aren't stopping my ride, and i definitely need to stop better.
just wondering what year i should get? 90-93? with all disc around and take the whole suspension and i should be fine?
Old Mar 27, 2003 | 10:22 AM
Default Re: integra suspension on a crx (nautica_t)
every bit of my suspension came from a 91 teg. the front control arms (upper and lower) are my stock ones, and same with the rear.
Old Mar 27, 2003 | 12:42 PM
civicmark's Avatar
did you use the teg springs/shocks too? how do they ride? are they too high and stiff, or too low and soft?
Old Mar 27, 2003 | 12:47 PM
nautica_t's Avatar
does a 96 gsr rear disc fit our civics?
and if they do what can i take off from the gsr rear discs setup??
Old Mar 27, 2003 | 03:56 PM
civicmark's Avatar
i dont believe so, but there's a slight chance i'm wrong
edit: i stand corrected, sorry
[Modified by civicmark, 2:31 PM 3/28/2003]
Old Mar 27, 2003 | 09:10 PM
any teg 90+ or civic 90+ rear setup will fit
i'm running the crx springs and shocks
Old Mar 28, 2003 | 01:07 AM
89civicdx's Avatar
I don't know what you guys are talking about I use 91 teg front knuckles/brakes on my car...no problems for me
I've used the teg front knucles on the track for 3 years and have had zero handling problems from them.
The only bad thing about teg front knuckles are they are heavy
[Modified by 89civicdx, 2:10 AM 3/28/2003]
[Modified by 89civicdx, 2:26 AM 3/28/2003]
Old Mar 28, 2003 | 05:32 AM
civicmark's Avatar
Default Re: integra suspension on a crx (89civicdx)
so, knuckles, spindles, and brakes all fit well. has anyone actually tried the controll arms, or rad rods?
thanks again
Old Mar 31, 2003 | 10:55 PM
JCracer723's Avatar
thanks again
i will like to know too
zephon96
Suspension & Brakes
Sep 27, 2005 04:27 PM
rewerbcrx
Sep 21, 2005 08:57 AM
gsrhatch530
Aug 16, 2005 12:35 PM
** OF HAZARD
Aug 16, 2003 05:19 AM
glagola1
Nov 23, 2001 03:39 AM
