obd0-1 conversion wont start
Old Mar 26, 2003 | 05:28 AM
KevronsEG's Avatar
Default obd0-1 conversion wont strat
its a d16z6 in a 91 crx si
checked teh injector wiring an dits good check teh dist. wiring and tryed doing teh white wire trick too. number 1 and 3 cly. spark plus are wet with gas and 2 and 4 cly spark plugs are bone dry. no spark i did teh screw driver trick. any ideas guys please help. also no codes too.
Old Mar 26, 2003 | 06:33 AM
red civic standard's Avatar
Default Re: obd0-1 conversion wont strat (CIV616)
so, you tried switching the white wires and still no spark?
try solving the no spark issue before moving to the injectors.
if you want, you can borrow my OBD0 to OBD1 harness.'
Luke
Old Mar 26, 2003 | 06:34 AM
KevronsEG's Avatar
Default Re: obd0-1 conversion wont strat (red civic standard)
i would think that woudl be it, cause it kinda started then died....
Old Mar 26, 2003 | 11:31 AM
KevronsEG's Avatar
help
Old Mar 26, 2003 | 05:23 PM
Ruby Civic's Avatar
not an expert, but just a thought - you must have juice going to the distrib, so maybe it is bad, and so not getting spark to the 2 cylinders, trace it from there is my guess.
if its two than prob not the obv. like injector plugs or harness....
Old Mar 26, 2003 | 05:24 PM
Ruby Civic's Avatar
make sure you check the fire on the plugs in the dry cyl. can you arc a current??
Old Mar 26, 2003 | 05:27 PM
KevronsEG's Avatar
Default Re: obd0-1 conversion wont strat (Ruby Civic)
where is this and how do i check it
Old Mar 26, 2003 | 08:41 PM
Fobtions's Avatar
im thinking you have a couple of the pins messed up.
[Modified by Fobtions, 9:41 PM 3/26/2003]
Old Mar 27, 2003 | 02:49 AM
NipponRacing's Avatar
Default Re: obd0-1 conversion wont strat (Fobtions)
main relay wires not hooked up right? did you use a jumper or did you splice the ecu plugs?
Old Mar 27, 2003 | 03:15 AM
KevronsEG's Avatar
Default Re: obd0-1 conversion wont strat (NipponRacing)
bought a jumper allready made
Old Mar 27, 2003 | 04:04 AM
Ruby Civic's Avatar
pulll the spark plug attached to the wire and arc it to metal like the block to see if you have fire
Old Mar 28, 2003 | 05:42 AM
problem is solved.
bad ignition coil led to no spark.
clogged fuel injectors led to wet plugs
[Modified by red civic standard, 6:43 AM 3/28/2003]
Fuzzy Rhubarb
May 20, 2008 05:25 AM
black92hatchback
12
Mar 8, 2005 04:59 PM
JohnnieChimpo
14
Dec 9, 2004 09:29 AM
KevronsEG
Mar 28, 2003 05:43 AM
KevronsEG
Mar 28, 2003 05:41 AM
