after resetting the ECU...
do you notice a drop in RPM's when braking to a stop? the needle drops under 500 and the lights dim... i pulled the fuse under the hood to reset...
pull the fuse to reset? i always thought just taking the negative/positive (i forget) terminal off the battery for 5 minutes reset the ECU...
fuse is there to prevent overload, and by taking it out, you disrupt the closed circuit.
