painted kosei k1
Old Mar 25, 2003 | 07:12 PM
magic hat #9's Avatar
Default painted kosei k1
i have received and started to paint my new kosei wheels.
remove the stickers, i eventually switched to straight blade which worked much better.
i sanded the wheels with 400grit paper to roughen up the clearcoat; the wheels turned a milky shade. i then primered the wheels with 2 coats of plasti-kote sandable primer from pep boys. i didn't bother wet sanding the primer so let's hope the paint sticks!
comparo
weapon of choice. fyi, i took 5 of these little cans to do 3 coats on 4 wheels. make sure you buy enough paint before you start because it might be hard to find the same color again. i know this....
the almost final product. the color is very dark (maybe too dark?). i'll post pictures with tires next week.
Old Mar 25, 2003 | 07:16 PM
Default Re: painted kosei k1 (magic hat #9)
ha! note the splash shield in the last picture. the mounting plugs were torn off long ago from too many autox cone impacts. at vir in february, the splash guard came loose and tangled with the tire; zip ties now own splash guards.
Old Mar 25, 2003 | 07:17 PM
Tommy_Gunns's Avatar
nice
Old Mar 25, 2003 | 07:23 PM
py1188's Avatar
Default Re: painted kosei k1 (Tommy_Gunns)
did you end up getting the 38 offset k1s from tire rack??
I'm still trying to find the distributor that picked up all the 45s, but I may still have to go back and get the 38s regardless.
Great job painting them though
Old Mar 25, 2003 | 07:24 PM
Todd00's Avatar
I said I don't want a title!
You painted silver ones? I thought they were white.
Regardless, looks good. I think I normally average 2.5 cans of paint for 4 wheels.
Old Mar 25, 2003 | 07:27 PM
kungfuSiR's Avatar
Default Re: painted kosei k1 (Todd00)
looks good i like the colour a lot
Old Mar 25, 2003 | 07:58 PM
Jowee's Avatar
Default Re: painted kosei k1 (kungfuSiR)
Don't forget clearcoat. Rims looking goood
Old Mar 25, 2003 | 10:09 PM
LiKe_WhOa!'s Avatar
Default Re: painted kosei k1 (ITR 98 1162)
can't you buy the wheels already painted in a gunmetal color?
Old Mar 25, 2003 | 11:46 PM
RagingAngel's Avatar
Default Re: painted kosei k1 (LiKe_WhOa!)
Yes if you buy the Buddy Club P1 instead....
Old Mar 25, 2003 | 11:57 PM
Art Vandeleigh's Avatar
looks great but what offset did you get?? i am guessing +38. but would like to make sure. i was alittle hesitant to get the +38....any issues? or do you plan to have any issues?
the offset is just alot.....and i didnt want any rubbing or any issues. thanks!
Old Mar 26, 2003 | 02:14 AM
itr-j's Avatar
Default Re: painted kosei k1 (Art Vandeleigh)
not so itr looking
Old Mar 26, 2003 | 02:39 AM
Kelvin96GSR's Avatar
25 Year Member
Default Re: painted kosei k1 (itr-j)
I've been looking for a bronzish color anyone know what spray I should go with?
Old Mar 26, 2003 | 03:15 AM
urbanlegend21's Avatar
New User
Default Re: painted kosei k1 (Kelvin96GSR)
just a note: where your lugnuts make contact with the wheel make sure the paint is rubbed off at that point, making it metal to metal contact with no paint layer between
before the paint will eventually rubs off with use it will make your lugnuts come loose very easily under normal driving
Old Mar 26, 2003 | 05:22 AM
Default Re: painted kosei k1 (urbanlegend21)
good point, will do!
Old Mar 26, 2003 | 05:25 AM
Default Re: painted kosei k1 (py1188)
yes, these are 38+ offset. i haven't test fit them with azenis yet, but there are several people here with no issues. if i find the don't fit, i will cry as obviously i can't return them to tirerack.
Old Mar 26, 2003 | 05:28 AM
aklucsarits's Avatar
New User
They used to be offered in gunmetal, but I don't think they are anymore. I have a set of the 16x7.5" +43mm K-1s in Gunmetal...
Andrew
Old Mar 26, 2003 | 06:05 AM
6ghatch's Avatar
Default Re: painted kosei k1 (aklucsarits)
Looks good! Will you be testing these at Lime Rock tomorrow?
Old Mar 26, 2003 | 06:21 AM
Default Re: painted kosei k1 (6ghatch)
nope, i'm still painting the last wheel. i will probably put on the clearcoat after limerock and then get tires put on next week. i will be using millenias wheels tomorrow.
bus stop's Avatar
THANK YOU
You just explain why I had loose lugnuts at the VIR last month. I was using my new "painted" wheels at the track and found that all the lugnuts came loose after each session which was never happen before !!!! Now I guess it must be caused by the paint.
Old Mar 26, 2003 | 08:09 AM
B_CRUZ!'s Avatar
why didn't you use the duplicolor wheel paint?
Old Mar 26, 2003 | 09:07 AM
98R-1144's Avatar
did you sand and paint the inside of the rims too? or just the face?
Old Mar 26, 2003 | 09:34 AM
Austin's Avatar
Me too
Old Mar 26, 2003 | 09:37 AM
Smitdog's Avatar
Default Re: painted kosei k1 (Austin)
I like!
Old Mar 26, 2003 | 11:04 AM
itr1244's Avatar
Default Re: painted kosei k1 (Smitdog)
good paint job
Old Mar 26, 2003 | 11:24 AM
Default Re: painted kosei k1 (BCRUZ)
no local autozone and walmart's stock was less than desireable. the paint i used is for autobody, but i don't know what real difference there would be other than packaging/marketing.
