Skunk2 stage1 cams
Old Mar 25, 2003 | 12:02 PM
pIMp NO's Avatar
Default Skunk2 stage1 cams
Is this a good cam for the H22a engine?
Old Mar 25, 2003 | 03:35 PM
One Slow Lude's Avatar
Default Re: Skunk2 stage1 cams (pIMp NO)
I have "heard" skunk2 are good cams, and my friend has a built civic with skunk2 cams and no problems. I want to get skunk2 stage 2 cams myself. As for the stage 1 I dont know the lift and duration specs. so i cant say. Check them against the prelude type s cams. If they are nearly the same it might be a better investment to stick with oem honda parts. The type s cam is also pretty good for a slightly better street cam, which i am assuming the stage 1 is also for. thats all the info i can give, sorry.
Old Mar 25, 2003 | 03:38 PM
sslude's Avatar
Default Re: Skunk2 stage1 cams (POSlude97)
go witht he stage two cams. skunk2 is one of the more popular cams. try a search, you might find some stuff on it. stage one and tw are most likely the same price, just get the stage 2, you wont regret it
Old Mar 26, 2003 | 01:01 AM
pIMp NO's Avatar
Default Re: Skunk2 stage1 cams (sslude)
If i'm getting stage 2 i need new retaiers and stuff I can't afford
Old Mar 26, 2003 | 10:16 AM
i believe that skunk2 "recommends" that you get their springs and retainers for stage two and says definately for stage three. It would be in your best interest to do that for the life span of your engine. Call them and ask what they think.
Old Mar 26, 2003 | 01:18 PM
piotrush's Avatar
You sure, I heard that they recommend the valve train upgrades for stage 1 (meaning "you don't need them, but spend $ on our products anyway"). And they require them for stages II and III. Also, I read in SCC that the stage 1 cams are also CARB legal, also a plus for a stret car. And a few GSR/ITR owners said they got respectable results from stage I with proper tuning.
Old Mar 26, 2003 | 01:54 PM
stylinlude's Avatar
Default Re: Skunk2 stage1 cams (piotrush)
the springs and retainers are only needed for the stage 2s if you plan on reving higher than the stock redline.
if you dont plan on using the stock rev limiter, then dont worry about it
Old Mar 26, 2003 | 06:36 PM
You sure,
no im not sure thats why i said "i believe....blah blah.....call and ask
if i knew i would say "i know that......
I dont doubt that the stage 1 puts out good power, my post said that you might want to look into type s cams if you just want a good slightly better street cam
StuPid oNe
Jul 2, 2005 06:08 AM
tone*def
Jun 14, 2004 01:21 PM
10K2HVN
Jul 4, 2003 02:28 AM
Fooser
Jun 25, 2002 06:26 AM
