Re-torquing crank bolt after valve adjustment
Old Mar 25, 2003 | 10:51 AM
Rtzx9r's Avatar
GDD 1%
Default Re-torquing crank bolt after valve adjustment
Hey- do you re-torque your crank bolt after valve adjustments like Helms says to do? You need a special tool to do so....
Thanks!
Old Mar 25, 2003 | 11:03 AM
SlapSmak's Avatar
Default Re: Re-torquing crank bolt after valve adjustment (Rtzx9r)
if you turn the crank with a ratchet slowly during valve adjustment you dont need to retorque it, unless you took the bolt off of turned it with an air ratchet.
Old Mar 25, 2003 | 11:11 AM
oryanh's Avatar
I'm going to take a guess and say because you made several manual rotations of the crank by way of adjusting the valves, I'd say they're over paranoid of possibly lossening the bolt.
Probably not that helpfull... worth atleast a bump.
___EDIT___ What he said^
[Modified by oryanh, 2:12 PM 3/25/2003]
Old Mar 25, 2003 | 11:19 AM
Rtzx9r's Avatar
GDD 1%
Default Re: Re-torquing crank bolt after valve adjustment (oryanh)
Thanks guys- I figured it was not necessary, just wanted to be sure. 2 intake, 1 exhaust valves were tight, btw.
Old Mar 25, 2003 | 11:36 AM
Tweakmeister's Avatar
that sucker is on there already.
I didn't bother
Dave-ROR's Avatar
FWIW, I've never retorqued it after doing a valve adjustment.
Old Mar 25, 2003 | 12:22 PM
Aaron M's Avatar
Default Re: Re-torquing crank bolt after valve adjustment (dawhiteboy)
isnt it torqued on at like 130 lb/s
which is pretty damn hard to loosen, no?
Old Mar 25, 2003 | 12:26 PM
Dave-ROR's Avatar
Default Re: Re-torquing crank bolt after valve adjustment (SilverB18C1)
145 I think? whatever it is I just impact it back on when I do remove the crank pulley bolt.
Old Mar 25, 2003 | 12:33 PM
EleanoR's Avatar
Helms says to torque it to 130.
Old Mar 25, 2003 | 12:35 PM
Dave-ROR's Avatar
Default Re: Re-torquing crank bolt after valve adjustment (EleanoR)
k, 130 then. either way, impact gun for me.
Old Mar 25, 2003 | 06:02 PM
py1188's Avatar
Yeah I think it would be really hard to loosen. But I guess it couldn't hurt to check
Old Apr 6, 2003 | 12:02 PM
illusion's Avatar
Default Re: Re-torquing crank bolt after valve adjustment (py1188)
whats wrong with just leaving the car in gear and pushing it to rotate the crank? i never both with that bolt..
Old Apr 6, 2003 | 03:04 PM
Floyd's Avatar
Default Re: Re-torquing crank bolt after valve adjustment (illusion)
That might work if the car is on the ground, but not when it's up on jack stands.
Just adjusted my valves today: 2 a little tight, and 1 a little loose. Didn't re-torque the crank bolt.
Old Apr 6, 2003 | 05:12 PM
BudMan's Avatar
fwiw - It's actually 134....and impacting it back on is what allowed it to come off during the last expo while chasing the viper down (1.5 laps before overtaking )
Old Apr 6, 2003 | 06:16 PM
Conechaser's Avatar
Default Re: Re-torquing crank bolt after valve adjustment (BudMan)
wow, the accord crankpulley bolt is tqd down to 181
Old Apr 7, 2003 | 06:40 PM
95GS-R's Avatar
Default Re: Re-torquing crank bolt after valve adjustment (94Accord)
I didn't when I did my valve adjustment.
I don't think you would loosen that thing at all as tight as it is on there.
Old Apr 7, 2003 | 07:15 PM
Dave-ROR's Avatar
Sounds like someone needs a real compressor
Old Apr 7, 2003 | 11:44 PM
WundedSaint's Avatar
remote starter switch, remove spark plugs....and use a ratchet on a cam to turn that extra 3/8 turn that you need to tdc it.......why use the crankpulley bolt??
Old Apr 7, 2003 | 11:54 PM
R-1303's Avatar
Default Re: Re-torquing crank bolt after valve adjustment (WundedSaint)
cuz its much easier..plus you don't want to mess with the delicate section of the cam gears and the alignment..plus you can also leave the spark plugs in..trust me its also recommended by honda.
D16SohcVtec
Nov 8, 2007 03:04 PM
chibiko
Feb 5, 2007 03:11 PM
vtec.dc2
Apr 26, 2005 08:17 AM
whitenameseboi
Mar 25, 2005 02:47 PM
maxxdout
Jan 23, 2002 05:10 PM
