Using a Skunk2 Rear tiebar for Harness mounts....
Old Mar 25, 2003 | 09:03 AM
*Boostwerks*'s Avatar
Default Using a Skunk2 Rear tiebar for Harness mounts....
Would the Geometry be correct for correct harness placement?
It does appear that the Bar is about a 1/2' lower then the top of the seats.
Thanks for any input.
Old Mar 25, 2003 | 10:26 AM
keithv's Avatar
Default Re: Using a Skunk2 Rear tiebar for Harness mounts.... (Bryson)
the geometry might be right, but that mounting points is not nearly strong enough to mount a harness to. i know i sure as hell wouldn't mount a harness there.
Old Mar 26, 2003 | 09:42 AM
Default Re: Using a Skunk2 Rear tiebar for Harness mounts.... (breaka_1_9)
Hrmmm...
The bar looks extreemly strong. . BTW, it is designed to be extreemly strong in the fact that it is BRACING the chassis. From what I can tell it is more then strong enough.
I have seen many RX7's with harnesses mounted to their rear strut bar, and all of them seem to be comparable to what it would be in the CRX.
I need more opinions on this.
Old Mar 26, 2003 | 09:48 AM
Audipwr1's Avatar
I would recomend you think more about this
if you roll your car while in a harness without at least one roll hoop in ur car. you and christopher reeves can take turns driving that chair of his
Old Mar 26, 2003 | 10:26 AM
Mr Furball's Avatar
Default Re: Using a Skunk2 Rear tiebar for Harness mounts.... (Audipwr1)
I would go with this option, I still don't understand why people ask questions and someone gives an answer yet the person who asked the question tells everyone that they are going to do it anyway.
Old Mar 26, 2003 | 10:39 AM
I am going with an Autopower "Race" Roll Bar.
The main reason of me asking this question, is if I could use the Tie Bar as a harness mount, then I can save 50 bucks by not getting the "harness bar" on the roll bar.
Old Mar 26, 2003 | 10:40 AM
Default Re: Using a Skunk2 Rear tiebar for Harness mounts.... (FURBALL B-16)
I still don't understand why people give stupid responses to questions I didn't even ask.
Old Mar 26, 2003 | 10:44 AM
Mr Furball's Avatar
What questions did you ask that I gave a response to, Please let me know because I was making a statement!!!!
Old Mar 26, 2003 | 11:54 AM
Audipwr1's Avatar
you can always make your own bracket for the harness off the autopower bar. not too hard, and you can have someone local weld it on for u
Old Mar 26, 2003 | 12:00 PM
wronghand's Avatar
In the big picture 50 bucks isn't that much. If you are getting a roll bar I think it would be crazy not to go ahead and get one set up for the harness. No need to skimp on safety.
Old Mar 26, 2003 | 12:12 PM
Spaceballsthelunchbox's Avatar
No Big Whoop
DO NOT use the Skunk 2 bar as a safety belt mounting bar.
That bar is made out of THIN HOLLOW extruded aluminum.
Do this, drill the holes needed for the safety belt, then jump on it at the point where you drilled. I bet you will go through it.
I have one.
Old Mar 26, 2003 | 12:30 PM
Default Re: Using a Skunk2 Rear tiebar for Harness mounts.... (Spaceballs the lunch box)
I know it's hollow. I have the front one as well, and I needed to grind a section out for the Idle control valve.
Thanks for your responses!
I guess I'm just gonna shell out the 50 bucks for the harness bar.
Old Mar 26, 2003 | 01:00 PM
Doctor CorteZ's Avatar
just get the harness bar and maintain the proper angles to avoid spinal compression , it doesnt seem too tough to me....
jdmfreak1992
Honda Civic (2001 - 2005)
Jun 29, 2012 02:01 PM
HypL
May 1, 2012 07:57 AM
Domo_Arigato
10
Jun 18, 2009 02:20 PM
ATS*Mark
30
Oct 26, 2004 05:31 PM
Tekwon-V
Jul 24, 2003 07:03 PM
