thoughts on place racing crossmember
Old Mar 25, 2003 | 06:28 AM
slowpokesi's Avatar
Default thoughts on place racing crossmember
http://www.afterhourzracing.com/shop...start=0&id=230
read this tell me what you think.
Old Mar 25, 2003 | 06:35 AM
FOrSfEd's Avatar
Default Re: thoughts on place racing crossmember (slowpokesi)
I ordered mine the other day.
Old Mar 25, 2003 | 06:36 AM
Mr Furball's Avatar
Get it. I have one and it's fine. I paid more then that also. I hate when you buy something and 6 months later it sells for 60 less. It's a good product and it goes right in. Also you get a front mount which I did not have and now I can put more power to the ground.
Just buy it. It is also good for the 4-1 jdm header. Pleanty of clearance.
Old Mar 25, 2003 | 06:39 AM
Home Skillet's Avatar
Default Re: thoughts on place racing crossmember (FURBALL B-16)
Did you need the modified radius arms?
Old Mar 25, 2003 | 07:19 AM
slowpokesi's Avatar
Default Re: thoughts on place racing crossmember (Home Skillet)
if u read that ad there is 2 cross members one you need the arms and one u dont.
im just curious as to wether or not this is comparable to the jimfab bar.
i would like to have the extra mount though for added stiffyness.
Old Mar 25, 2003 | 07:38 AM
philly-O's Avatar
how well does the 4th motor mount line up if using HASport mounts? also curious on how it compares to the jimfab unit.
Old Mar 25, 2003 | 07:46 AM
Steve91's Avatar
I've had one for a year now and love it. Fit great and only took about 20 minutes to install. I don't run the front mount since I have a D16. With the Prothane inserts in the other 3 muonts, the motor barely moves at all.
BTW, I don't know what their talking about with the modified radius rods. My stock ones went right in.
[Modified by Steve91, 8:48 AM 3/25/2003]
Old Mar 25, 2003 | 07:58 AM
Eggman's Avatar
Wow, I didn't know there are 2 different models (CM101 and Cm102). Place Racing really needs to get their site up. Anyone get the CM101 with the different radius rods? We're all interested to hear a review on that one compared to the JimFab and Z10 counterparts. Especially since the PRI one is so much cheaper.
BTW, thats sucks how that site ripped off the pic from JDMHondaParts.
C
Old Mar 25, 2003 | 09:46 AM
Mr Furball's Avatar
Default Re: thoughts on place racing crossmember (peichie)
Unless ha sport sent you the 4th mount you should not have that one. The mount comes with the Xmember and it fits fine.
Old Mar 25, 2003 | 09:50 AM
Mr Furball's Avatar
Default Re: thoughts on place racing crossmember (Eggman)
The jimFab Xmember looks better but both are pretty much the same except for the pillow *****. Thats the only differance that I can tell. Does same thing and fuction is same OH yeah I just thought of another reason why they are different, look at the price tag, Place racing has a way better price.
Old Mar 25, 2003 | 12:10 PM
b16_madman's Avatar
I'm running the stock front crossmember, hasport mounts. Yeah with my B I notice lots of wheelhop. This cures it I know, gives more room, but which one should I buy?
Place Racing w/out the mount? I guess so. Do I need the radius arms too, or use the stockers.?
Old Mar 25, 2003 | 12:38 PM
Denny317's Avatar
I like mine...though one of my tow hooks is on the verge of breaking off due to scraping.
Old Mar 25, 2003 | 01:00 PM
b16_madman's Avatar
Default Re: thoughts on place racing crossmember (Denny317)
who needs tow hooks on a honda! jk, theyre light and dependable, and if in a wreck youre screwed either way. that is now on the to buy list
Old Mar 25, 2003 | 04:31 PM
NCchris's Avatar
Default Re: thoughts on place racing crossmember (B16_madman)
B4 you drop a lota cash, try the poly radius rod bushings in the stock xmember. They made a big diff in my car.
HTH
chris
Old Mar 25, 2003 | 04:44 PM
trent58353's Avatar
I def need the REar crossmember and connecting lower control arm for an 89 crx si...
Please contact me ASAP if you have those parts or at least one
Thankyou
Old Mar 25, 2003 | 04:46 PM
trent58353's Avatar
Default Re: thoughts on place racing crossmember (FOrSfEd)
Definately need the REar crossmember and connecting lower control arm for an 89 crx si...
Please contact me ASAP if you have these parts or one.
Thankyou
Old Mar 25, 2003 | 07:51 PM
Vtecless212's Avatar
Default Re: thoughts on place racing crossmember (trent58353)
i'm about to order the place racing crossmember it's my understanding that it holds the 92-95 civic radiator but my ? is what happens to the stock rad. mounts and what all does it come with?
Old Mar 25, 2003 | 07:57 PM
philly-O's Avatar
try calling lance at link motorsport, he has a couple 88-91 si's. you can get his number off his website http://www.linkmotorsport.com i dont know if he would ship it or not but definately worth a try. tell him phil sent you.
Old Mar 25, 2003 | 08:01 PM
i have some rear crossmembers and a couple pairs of lower control arms and other susp. pieces for a 91 crx tho so let me know
Old Mar 26, 2003 | 07:47 AM
Eggman's Avatar
Alright, I called Place Racing yesterday...and they said that they have two crossmembers for EDs.
One is basically a stock replacement that has better clearance for a turbo/header, B-series front mount spot, and can support a EG radiator.
The second crossmember they have was designed for the their H22 swap kit. Hence the modified radius rods needed.
I suggest anyone that plans on buying the second one, call Place Racing first to verify what you are getting.
Old Mar 26, 2003 | 09:20 AM
cornholioEK's Avatar
is the place racing cross member better than the Z10 cross member? and whats place racings' site?
Old Mar 26, 2003 | 09:21 AM
FourthGenHatch's Avatar
Out of Z10, Place Racing, and Jim Fab, who is the best/for the money?
Old Mar 26, 2003 | 09:37 AM
Mr Furball's Avatar
Default Re: thoughts on place racing crossmember (FourthGenHatch)
Place racing, because it's light weight and comes with the front mount no extra cost.
Old Mar 26, 2003 | 10:13 AM
Vinceg99's Avatar
So is it worth getting something like that for a D16? I am swapping out my DX motor for an Si motor and was thinking to get it since I will have the car ripped apart anyway so I was just curious if it would be worth it for me?
Old Mar 26, 2003 | 10:34 AM
Flexmyrex's Avatar
Default Re: thoughts on place racing crossmember (Vinceg99)
anyone got a pic of their optional radius arms, i wanna know if theyre adjustable like the z10 arms
if not ill just use my stock r arms
