Can i use 1 vacuum-line to supply.......
.....vacuum to the blow-off valve and wastegate. For in instance, can i use the map sensor vacuum line to T-off to the bov and waste gate? --->i tried searching, but either i'm not making my self clear or there is no topics on this matter, wich i highly doubt. Thanks.
you can, but its best if you dont T off the wastegate. you should run it from the compressor side of the turbo or brake booster line.
