bought nx stage 1 wet kit have some setup Q's
Old Mar 24, 2003 | 05:25 PM
thehondaguru's Avatar
Default bought nx stage 1 wet kit have some setup Q's
I hate asking questions like this but I did what the topic says and just need to know what I should do. I have cam gears and a vafc. Should I put all the settings on the vafc back to normal and redyno it with the nx kit or is it safe to leave it where it is. And I know you arent supposed to advance ignition timing but what about Cam timing, my exhaust cam is retarded 3 degrees and nothing on the intake side, Is it safe there or should it be put back to normal. Also what is a safe fuel pressure to run at because I have a fuel rail and pressure regulator too. I am running it at about 31 psi at idle and dont remember what its at at wide open throttle prebebly around 39 psi. I think stock pressure is 40 psi at wide open throttle but not sure. Also, to set the pressure at wide open throttle you just pull of the vacuum line on the regulator, correct? I just want to clarify all of this before I **** something up and I love my prelude too much to do that. If you can help please do this is very important. Thanks alot
Old Mar 24, 2003 | 07:05 PM
laughinxxx's Avatar
New User
Default Re: bought nx stage 1 wet kit have some setup Q's (95 lude)
You can leave the VAFC settings alone as long as your fuel pump is providing enough fuel. The cam gears should be fine at their present setting. Your best bet will be to get on a dyno and check everything. You may be able to make some more hp with a bit of tinkering.
Old Mar 24, 2003 | 07:07 PM
Default Re: bought nx stage 1 wet kit have some setup Q's (laughinxxx)
thanks. Should I change my fuel press. like up to maybe 41 or 42 at wot just to be safe with getting to lean.
Old Mar 24, 2003 | 07:18 PM
laughinxxx's Avatar
New User
Put it back to stock/40 psi for your first dyno run. There is no need to go above 40.
ITR.#1446
Mar 25, 2004 01:02 PM
Boosted Gsr Hatch
Mar 9, 2003 06:58 AM
LB CRX
Apr 30, 2002 06:25 AM
