Interesting dashpot findings
Old Mar 24, 2003 | 01:15 PM
Malgerus's Avatar
Default Interesting dashpot findings
Well, I had removed the one dashpot off of my B16A (5 million series), and I found out someting interesting. After I had taken it off, I had problems with the cable sticking whenever I would press the gas pedal. At first I thought it was too loose, but I tightened it up and nothing. After i put the thing back on, it fixed my problem! My gas engagement is smooth as hell! So if you guys are in a similar situation, you may want to put yours back on. Interestingly, Raene took both of his off, and he has no problems with the cable sticking, except at startup. Just thought I'd share this knowledge.
Old Mar 24, 2003 | 02:21 PM
Ef Whore's Avatar
Default Re: Interesting dashpot findings (Mr. S)
I took mine off my a6 soon as I got it...no more shift lag.
Old Mar 24, 2003 | 02:52 PM
b1reed's Avatar
Default Re: Interesting dashpot findings (Ef *****)
this may sound stupid and but wth is a dashpot?
EDIT: sorry for my newbism
[Modified by b1reed, 2:02 AM 3/25/2003]
Old Mar 24, 2003 | 03:40 PM
Malgerus's Avatar
Default Re: Interesting dashpot findings (b1reed)
Yeah, the funny thing is, my brother's car works fine without them. Weird.
b1reed, it's a funny little thing that sits right beside the throttle body. It has a vacuum line that goes into the air intake tube, and it basically smooths out the engine rpm when you're shifting, etc.
Old Mar 24, 2003 | 03:58 PM
89civicdx's Avatar
I don't use the dashpot and don't have any sticking problems.
When did it stick when opening or closeing?
If it was when opening you should play with the throttle plate stop screw to set the plate slightly open as if the dashpot was still attached then use the idle screw to bring the idle back to spec.
Most of the plates will stick from a fully closed positon especaily after warm up.
smeags
10
Jul 20, 2013 10:22 AM
truxvi3tz
Mar 31, 2010 02:26 PM
stodom4l
Jul 17, 2008 04:17 AM
Kangolbrand
Nov 30, 2006 09:50 AM
joeg26er
Feb 19, 2003 06:15 PM
