budget turbo in honda tuning!!
Old Mar 24, 2003 | 12:53 PM
egchan's Avatar
Default budget turbo in honda tuning!!
did anyone read about the budget turbo in the latest honda tuning? i always knew that the hf manifold was easy to fabricate, but to get 170 whp from a stock motor and a 2nd gen eclipse turbo... hell yeah! i have a friend that can get me the turbo and side mount, and i already have an hf motor in my garage. the only thing i'm unsure about is if the hf manifold bolts to a z6 block. it should since its d series, right? any reactions and help would be interesting. i think i have a new project
Old Mar 24, 2003 | 12:57 PM
whizdumb's Avatar
Default Re: budget turbo in honda tuning!! (SlickCRX)
Yes the HF mani bolts up the Z6 head, check out http://www.homemadeturbo.com
Old Mar 24, 2003 | 01:00 PM
spun Vtec's Avatar
you have to make an adaptor plate for the t25 to bolt to the hf manafold
Old Mar 24, 2003 | 01:13 PM
ucacrx's Avatar
Default Re: budget turbo in honda tuning!! (shiznattik)
ghetto turbo kits rock
good luck with your project..
here is a link Re: hf mani for your set-up..
http://www.tunertoys.com/tech/HFManifoldD16.htm
Old Mar 24, 2003 | 03:08 PM
EG8R's Avatar
Default Re: budget turbo in honda tuning!! (ucacrx)
Ok Ok!!! What about say.... a 96 Civic exhaust manifold??? The cat looks to be in the same place as an HF. I've never seen an HF so I dunno for sure....
I think I can get one of those manifolds....
Old Mar 24, 2003 | 03:12 PM
cottagecreep's Avatar
Default Re: budget turbo in honda tuning!! (mr. skelly)
You have to cut the cat off than make an adapter plate and a flange etc. A lot more work than an hf one, go for it if you have one though.
Old Mar 24, 2003 | 04:47 PM
FullMetalJacket's Avatar
Default Re: budget turbo in honda tuning!! (cottagecreep)
88-89 std manifold flows better than the HF manifold...I was gonna do that set up but I think I need a new engine and trans
90goldhatch
Oct 2, 2008 01:26 PM
junior40er
Oct 17, 2006 05:58 PM
USDM 4G VTEC
Aug 19, 2002 10:37 PM
89 CRX SI
Apr 8, 2002 09:15 PM
