GSR Vtec wiring problem in EG
Old Mar 24, 2003 | 12:30 PM
shorty's Avatar
Default GSR Vtec wiring problem in EG
ok.. had my swap done for quite some time now... still NO VTEC... we did the wiring ourselves, using my old DX harness and simply added the vtec wires ourselves... but here is the deal..
i turn on my car no check engine light.. when i drive it and wanna hit vtec i get a check engine light, check the code (21) vtec solenoid....so im like ok if i take it to a shop now and see if they can run some diagnostic tests.. the 1st thing they are gonna tell me is "you need a new wiring harness" or "get the proper wiring harness"
but this is what REALLY gets me...
Have swapped ECU's from a car that i KNOW vtec works on.. nothing
Have checked the lil screen to see if its dirty.. it wasnt
no dents in oil pan
oil filter is brand new
oil level is FINE
so im like... hmm maybe it has somthing to do with the 1 vtec solonoid wire going from the ECU to the solenoid.. so i run another one, using the SAME wire that is the SAME guage... wire it up... turn on my car... check engine light RIGHT AWAY...
DOES MY ECU HAVE A THING FOR THIS 1 WIRE? I DONT GET IT?
ANY SUGGESTIONS? **** ill try anything...
flame me? **** i dont care
Old Mar 24, 2003 | 12:42 PM
slowdx's Avatar
Default Re: GSR Vtec wiring problem in EG (shorty)
Did you run the vtec wire straight from the solenoid to the ecu?
I have a 95 gsr in my 95 civic dx and the same thing happened to me.
WE ran the wire again, nothing, we ran it one more time and it worked, i dont know what was wrong but it worked. I know i didnt help much but just try running it again. Or get a test light and see if there is any current running through the wire when you are running the car or rev to vtec.
Maybe its not the wiring, and your solenoid is bad?
Old Mar 24, 2003 | 12:53 PM
shorty's Avatar
Default Re: GSR Vtec wiring problem in EG (slowdx)
Yes the vtec solenoid wire is run straight from the solenoid to the ECU
the 1st wire that we ran:
Start up: no check engine light
Try to hit vtec: check engine light (solenoid)
2nd wire that i ran outside my car (simply for testing):
Start up: check engine light RIGHT away (solenoid)
3rd wire that i ran through firewall:
[Modified by shorty, 1:55 PM 3/24/2003]
Old Mar 24, 2003 | 01:55 PM
slowdx's Avatar
Dont really know what to tell ya man. Sorry, free bump for ya.
Old Mar 24, 2003 | 02:34 PM
shorty's Avatar
ttt
Old Mar 24, 2003 | 03:53 PM
TREVER's Avatar
whats your oil pressure?
Old Mar 25, 2003 | 05:08 AM
shorty's Avatar
Default Re: GSR Vtec wiring problem in EG (TREVER)
i dont know...
Old Mar 25, 2003 | 09:23 AM
shorty's Avatar
ttt
Old Mar 25, 2003 | 03:24 PM
TREVER's Avatar
you nedd around 30 psi for vtec to engage. get a cheapo gauge for about 20 bucks and check it.
Old Mar 25, 2003 | 03:30 PM
TREVER's Avatar
I thought that 21 was the oil pressuere code put it's not I have the del sol book here I'll try to help you out. first off see if your solenoid wire (the single wire connector) is connected to a4 at the ecu. a4 is on the 26 pin conn it is the second wire on the bottom row.
Old Mar 25, 2003 | 03:57 PM
shorty's Avatar
yes the wire is connected, and is getting current... 1 wire gives me a check engine light ONLY when i try to hit vtec, so i ran another wire.. the SAME type of wire and everythign.. and i get a check engine light when i turn on my car... i dont get it...
Old Mar 25, 2003 | 04:13 PM
TREVER's Avatar
How do you know it's getting current? you need to check for continuity between the solenoid connector and the a4 plug at the ecu. do you have a dvom?
[Modified by TREVER, 5:15 PM 3/25/2003]
Old Mar 26, 2003 | 07:52 PM
shorty's Avatar
dvom? i hooked up my multimeter, and it's getting volts, im not sure what setting to put it on to measure current...
Old Mar 26, 2003 | 08:11 PM
redsin's Avatar
is it a usdm motor? also why r u using the dx harness. the gsr plugs in if its usdm. and jdm vtec selenoids need to be changed to us. i don't now if this will help but its some more ideas.
Old Mar 26, 2003 | 08:29 PM
shorty's Avatar
Default Re: GSR Vtec wiring problem in EG (redsin)
its a jdm swap... havent found a damn gsr harness... would like to get one local.. but no junkyard has one.. honestly i have been trying to find one for about 6 months... the pple that do have them sell them when they do swaps, they dont wanna let one go on its own, and no a gsr doesnt plug up right if its usdm... dx = no vtec.. thats why we simply made our own vtec wires...
Old Mar 26, 2003 | 08:40 PM
redsin's Avatar
everything but vtec will. and if its a 92 all models are pre wired for vtec.. don't know what year your car is.... i think its the vtec selonoid. im pretty shure you have to get a us one.... someone elts can get clearer on why.....
Old Mar 26, 2003 | 10:09 PM
shorty's Avatar
its a jdm ecu too though... i have never heard that the solenoid itself would have to be changed just because its jdm... hell it could be bad.. i dont know...
Old Mar 27, 2003 | 06:28 AM
976's Avatar
976
New User
Can you try a VX harness?
Old Mar 27, 2003 | 07:16 AM
shorty's Avatar
Default Re: GSR Vtec wiring problem in EG (w00t!)
doono.. i know i can use an ex harness but i would have to make my own knock sensor plug... but.. i just hate the thought of ditchin out $100+ just for 1 wire... tryin to make sure its not anything else.
Old Mar 27, 2003 | 08:25 AM
black-hatch's Avatar
isnt the vtec solenoid suppost t have a ground check and make sure it is grounded just my 2 cents
Old Mar 27, 2003 | 11:55 AM
Kamin's Avatar
what? no?
you dont need a usdm solenoid.
Old Mar 27, 2003 | 01:02 PM
TREVER's Avatar
you can't measure current/amperage with a volt meter you need a ohm meter. A dvom is a digital volt ohm meter. You need to check for continuity in your solenoid wire. Unless you want to start throwing parts at it for no reason.
Old Mar 30, 2003 | 07:10 PM
shorty's Avatar
ttt
Old Mar 30, 2003 | 11:41 PM
salbaje's Avatar
maybe you are reading the code wrong?? have you tried a us ecu??
[Modified by salbaje, 7:29 PM 3/31/2003]
Old Mar 31, 2003 | 05:24 AM
shorty's Avatar
Default Re: GSR Vtec wiring problem in EG (salbaje)
read 2 lines...?
