Earlier ITRīs revs higher??
Hi!
After installing the Spoon ECU, fuel cut of is at 9000 rpm like specification. But with my original ECU i could also rev until aprox. 8700 rpm.
I thought always, my rev-meter is going wrong, but with spoon ECU it cut off at 9000.
May some ITRīs revs higher than 8400 ???
Or can following be:
The rev-signal comes from the ECU, the Spoon ECU is going more exactly like my original ECU??
[Modified by ITR292, 9:31 PM 3/24/2003]
Your grammar makes my brain hurt.
)Yes i read the rpm from the tacho.
The only thing i dont understand is, that with the Spoon ECU the cut off is at 9000 like it should be. But with stock ECU its above 8400
Ok guy, lets talk in German... (Hope you are not able to..
Sicher, können wir auf Deutsch sprechen, wenn Sie wünschen. Gut, ein anderes europäisches Hype R zu sehen.
)Sicher, können wir auf Deutsch sprechen, wenn Sie wünschen. Gut, ein anderes europäisches Hype R zu sehen.
stock fuel-cutoff is 8600, the posted redline is 8400. Of course, most people find their rev-limiter a few times. Also, as mentioned, the stock tachometer isn't totally accurate at those engine speeds.
And his grammar is superior to the majority of the american population, i'd say...and we don't have the second-language excuse
Wait, let me type it this way.
Scott... did not you notice.. but.. the stock p73... ecu.. programming signals cutting of fuel at 8500.. rpm... my grammer and schpeliong are prefekt.
edit: ITR292: this was not in reference to you, just some of the US citizens who type like that in every post.
[Modified by dawhiteboy, 4:04 PM 3/24/2003]
