How to tell, bad rings/bad seals?
Old Mar 24, 2003 | 09:33 AM
Eggman's Avatar
Default How to tell, bad rings/bad seals?
My engine is burning crazy amounts of oil. Going to pull the head off soon.
1. What do I look for to determine my valve seals went bad?
2. What do I look for to determine my oil rings went bad?
Thanks,
C
Old Mar 24, 2003 | 11:06 AM
94CivicSi's Avatar
Default Re: How to tell, bad rings/bad seals? (Eggman)
I'm not sure how you could diagnose a bad valve seal. To check the ring tolerances, you've got to the pull the pistons, slide the ring into the cylinder and measure the end gap.
Are you sure you're burning this oil and not just losing it from a slow leak? What do the spark plugs look like? Any blue smoke?
There are products out there that will condition old seals and stop some internal leaks, like if you had a bad valve seals. A friend of mine put some Lucas Oil Treatment in his motor and after about 3000 miles, stopped burning oil comletely.
Old Mar 25, 2003 | 07:47 AM
Eggman's Avatar
Default Re: How to tell, bad rings/bad seals? (94CivicSi)
No drips/leaks.
Plugs look fine.
Compression ~280, all across.
Leak down says 1%, all across.
Burns at least 3 quarts a week.
Smokes out the back when I 'get on it'. Kinda bluish I guess.
Old Mar 25, 2003 | 09:10 AM
gitwidit's Avatar
To diagnose bad valve seals or valve guides one of the easiest things to do is let it sit and warm up, take it out, beat the snot out of it for a few then park it and turn engine off, give it about 10-15 minutes and start it back up, if it smokes at start-up while idling then the leak is usually up in the head. When this happens basically oil is leaking down through the head and sitting in cylinders, when you start up it burns off right away.
Old Mar 25, 2003 | 09:17 AM
GSRMatt's Avatar
25 Year Member
Default Re: How to tell, bad rings/bad seals? (GITWIDIT)
If it smokes under full throttle it is typically the rings, if it smokes under deceleration (high vacuum conditions) it is typically the valve guide seals.
Old Mar 25, 2003 | 11:02 AM
Eggman's Avatar
Default Re: How to tell, bad rings/bad seals? (GSRMatt)
Well, it definetly smokes alittle after the car sits for awhile. And that last for about 2 minutes. It smokes occasionally when I accelerate hard.
Are there any visiable characteristics to look for, as I will have to remove the head regardless.
Thanks all,
C
Old Mar 25, 2003 | 11:38 AM
dkim48's Avatar
If you are sitting there for a little while and take off then its the valve seals. The reason for the big puff of smoke after starting the car or just sitting there idling is because the valves are constantly leaking but because its not be pushed hard it is not burning as bad. I dont know if this makes sense to you but most likely it is your valve seals. But they must be pretty bad to burning 3 quarts a week. Good luck fixing it.
Old Mar 25, 2003 | 11:39 AM
nolimits's Avatar
Are you using a turbo? If so the seals could be worn and oil's leaking into the exhaust. If it passed a compression and leakage test as good as it did, then I don't see how it could be rings/valves. Did you say 280psi compression??
Old Mar 25, 2003 | 12:11 PM
Katman's Avatar
this might be a little extreme and quite worksome, but you might wanna check your actual valves themselves, as in take your head off inspecting the underside of your head.
A few years back, a friend of mine had a JDM GSR engine in his EG; he drove on it for quite a while; from memory it smoked from day; we could never figure out why until we took his head off one day. What we found was that 1 and only 1 of the valves (can't remember if it was an intake or exhaust valve) actually had a piece of it missing (like small pie peice cut from the valve's big round foot).....it somehow broke off and was probably like that shipped from Japan too.
so you might wanna check on that if you're up to it...
Old Mar 26, 2003 | 04:49 AM
JimBlake's Avatar
Default Re: How to tell, bad rings/bad seals? (nolimits)
... If it passed a compression and leakage test as good as it did, then I don't see how it could be rings/valves. Did you say 280psi compression??
Compression & leakdown tests will not show valve stem seals. The valves themselves are closed, so those tests will show leaking rings or valve seats.
Leaking valve stem seals also leak more under high vacuum, like idling or engine-braking.
Old Mar 26, 2003 | 05:24 AM
GM2000ITR's Avatar
New User
GSRmatt hit it on the money.
[Modified by GM2000ITR, 6:26 AM 3/26/2003]
Old Mar 26, 2003 | 05:29 AM
gitwidit's Avatar
Default Re: How to tell, bad rings/bad seals? (JimBlake)
I think nolimits was questioning the 280psi, kinda high don't ya think?
Old Mar 26, 2003 | 07:52 AM
gitwidit's Avatar
Default Re: How to tell, bad rings/bad seals? (GM2000ITR)
Under extreme vacum, getting into high r's and letting off the throttle it is actually possible to pull oil past your rings.
Built4Battle
Oct 23, 2010 03:55 PM
lilshady6796
May 24, 2009 04:07 PM
BiG_DeE
16
Feb 9, 2008 11:53 PM
mickiemagik
May 21, 2007 06:16 PM
EF'n Sedan
Mar 15, 2006 08:37 AM
