Acuple of problems, I need help.
Old Mar 24, 2003 | 08:46 AM
The_PissingDog_Crx's Avatar
Default Acuple of problems, I need help.
There's oil on my spark plugs but i changed the O rings and valve cover seal a while ago. Can oil leak into the spark plus if the head gasket is blown? there's also oil leakage on the side of my motor where the cam gear is also...i'm not sure where it is coming from.
there's also radiator fuild leaking from somewhere. i checked and it's not the lower or upper radiator hoses. it looks liek it's coming from somewhere behind the engine. any ideas?
thanks.
Old Mar 24, 2003 | 09:48 AM
Redline130's Avatar
Default Re: Acuple of problems, I need help. (The_PissingDog_Crx)
For the oil on the side of the motor, I'd say that your cam seals are in need of replacing. As for the fluid leak, check your water pump. Could be that your water pump is leaking the fluid.
Old Mar 25, 2003 | 08:37 AM
matt j's Avatar
Default Re: Acuple of problems, I need help. (Redline130)
for oil on your spark plugs how long ago did you change the valve cover gasket and is there any creases in it or anything like that, it sounds like the grommets have gone bad on the gasket, as for the oil on the cam side of the motor, sounds like a cam seal, and coolant sounds like water pump or maybe a cracked radiator.maybe even a leak from on of the coolant hoses that goes to the tb or the thermostat housing could be leaking also
adio8352
May 2, 2011 08:03 PM
1997accordlx
Jan 7, 2010 12:32 PM
vtec2190
Jan 5, 2009 05:59 PM
da1lydr1ver
13
Dec 6, 2006 06:04 PM
jdmgeorge
Feb 18, 2004 12:45 PM
