mixing oil weights
Old Mar 24, 2003 | 07:48 AM
See Are X's Avatar
Default mixing oil weights
good? bad?
Old Mar 24, 2003 | 07:51 AM
da94ludesi's Avatar
Default Re: mixing oil weights (See Are X)
nah.....go for it.....no really.....just stick with the same oil
Old Mar 24, 2003 | 08:06 AM
See Are X's Avatar
Default Re: mixing oil weights (da94ludesi)
my car is burning a little bit of oil. Im now using 5w30 and I think I should switch to 10w40...adding a little 10w40 into the motor as the 5w30 slowly burns off
Old Mar 24, 2003 | 08:09 AM
da94ludesi's Avatar
no, i dont see any problem with this, but when you change your oil i would definatly use one type of oil
Old Mar 24, 2003 | 09:58 AM
dip-set's Avatar
time to thread jack....wghy is motor oil brand switching bad...i use mobil 1 synthetic blend but like the castrol gtx better..makes the engine feel more smooth and solid to me....pros/cons....shoot them this way...
Old Mar 24, 2003 | 10:56 AM
philstireservice's Avatar
Don't add 10w40...it will not fix the problem only make it worse. i.e. gum up the motor. if you are burning oil you should find the problem ....or just keep adding the the correct viscosty oil......
Old Mar 24, 2003 | 10:58 AM
Default Re: mixing oil weights (teg-your-it)
if you want a good (the best) synthetic oil, use Amsoil......philstireservice.com...click on the Amsoil link and see why
Old Mar 24, 2003 | 11:20 AM
altoid's Avatar
each type of oil has its own additions and its easier on the engine if you are brand loyal. i don't know how harmful it is, money's been tight arouund here nd i just switched to a less expensive oil on my cars, no difference, though they are both stock.
Old Mar 24, 2003 | 11:53 AM
ejprimo's Avatar
Default Re: mixing oil weights (Maxx44)
of course the amsoil corporate website would say that amsoil is the best synthetic oil. im sure ill find that castrol syntec is the best synthetic oil on the castrol corporate website.
HA0LEFIED
Honda Civic (2006 - 2015)
Nov 18, 2007 08:23 PM
old_school_dohcvtec
Feb 10, 2005 06:03 PM
See Are X
Mar 19, 2003 09:05 AM
ithrowpoop
Mar 10, 2003 02:00 PM
crxhybrid1320
Feb 7, 2003 05:22 PM
