Took her to the dyno....
Old Mar 24, 2003 | 07:44 AM
ACRXGuy's Avatar
Default Took her to the dyno....
Here are the pictures of the dyno plot and the car.
I have a bad clutch and I cant get traction so I cant pull the time I know the car can run. On the falkens I pulled a 14.4 at 97 mph, oh well, anyone have a set of slicks I can borrow?
Old Mar 24, 2003 | 07:48 AM
REDBARON's Avatar
Default Re: Took her to the dyno.... (ACRXGuy)
Not bad. Not bad at all. I'm sure you will get much better times once you get those slicks.
Old Mar 24, 2003 | 09:20 AM
91_hatch_si's Avatar
Default Re: Took her to the dyno.... (REDBARON)
will some slicks, you will be seeing 13s, and a good clutch
Old Mar 24, 2003 | 11:40 AM
kill bill's Avatar
Default Re: Took her to the dyno.... (91_hatch_si)
you are right, something is definitely wrong with running a mid low 14 on a type r block. my very first crx with a bone stock b16 and IHE and a chipped ecu went 14.2s on honda blackies with generic tires.
Old Mar 24, 2003 | 11:46 AM
ACRXGuy's Avatar
Default Re: Took her to the dyno.... (i need space)
I find a 14.2 hard to believe. I see people at the track all the time and no one in a b16 can pull that kind of run. I know I can do better, but a slipping clutch and no traction off the line is killing me. Give me a set of slicks and a good clutch I am sure 13.5 is easy to pull off. If you are that good of a driver then props to you, but a 14.2 is hard to believe.
Old Mar 24, 2003 | 12:00 PM
wannab20hatch's Avatar
c-mon 14.2 that is hard to believe maybe high 14s or really low 15s maybe low 14s on slicksmy friend in a hatch w/b16a stock exhaust and a filter on the end of his intake tube ran a 15.2 and his hatch is just as light as most crx's
Old Mar 24, 2003 | 12:13 PM
wuhungsixxx's Avatar
New User
yea times are slow for the power your putting down...i have the exact same times and im putting down ~150whp and ~115lbs TQ on a stock block and head B18C, but i have a good clutch...and i still think im slow...low-mid 13s with them #s plus slicks and a good clutch
Old Mar 24, 2003 | 12:19 PM
REDBARON's Avatar
Default Re: Took her to the dyno.... (wannab20hatch)
You also have to take elevation, and temperature into account. The same car will run different times at different tracks depending on the elevation, and temperature.
I personally ran a 15.1 in my 91 CRX HF with B16. This was my very first time at the track with my B16. I have I/E/ 16" heavy rims, with Nitto 450's. It was run at the Ennis, TX track at around 70-80 degree weather. Not a great time, but like I said it was my first time at the track with my B16. I can launch way better now, but I've yet to go to the track again.
Old Mar 24, 2003 | 01:22 PM
JustChou's Avatar
Are your rims sized differently? It looks like your fronts are larger in diameter.
Old Mar 24, 2003 | 01:35 PM
HondaPartsHero's Avatar
Technical Hero
i don't find a 14.2 hard to believe, my 89 hatch with 92 b16a, I/H/E/UR underdrive pulley, ran 14.1@94 on slicks and a 14.6@96-97mph with steelies, the car weighed 1925lbs without me in it and 2100lbs with me in it. (Rockingham Dragway, Rockingham, NC).
Old Mar 24, 2003 | 01:46 PM
ACRXGuy's Avatar
Default Re: Took her to the dyno.... (yebabee)
No those are all the same size. I weighed my car and it came in at 1950 without me in it and 2100 with me in it. A 14.1 with slicks is more believable especially with that weight. He said he ran with generic tires, I would love to race him even with my bad clutch. To bad he is in Cali. I also need to raise my rev limiter to 8600 and stay in the gear a little longer. I am shifting right at the 8200 rev limiter right now. That should pull a little more time off too. Does a VAFC change the rev limiiter? or just the VTEC engagement point? I dont know to much about that thing.
Sal
Old Mar 24, 2003 | 02:39 PM
Jeff C's Avatar
Nice dyno numbers.
Old Mar 24, 2003 | 04:47 PM
kill bill's Avatar
Default Re: Took her to the dyno.... (Jeff C)
believe what u wish.
Old Mar 24, 2003 | 09:23 PM
pokemon's Avatar
Yea those are shitty #'s. I got a friend that ran a 14.4 on stock 13inch steelies with a b16, I/H/E
Old Mar 24, 2003 | 09:41 PM
orgasmicsensations's Avatar
Default Re: Took her to the dyno.... (pokemon)
91 crx with b16, stock rims, full exhaust, a guy i know, ran 14.7 at the track, and he's pushin 230 pounds. just exhaust though.
i might get a b16, when i do i'm gonna hook like a bitch. lsd, coilovers with camber kit, nitto 15" 205/40's. should be fun.
Old Mar 24, 2003 | 11:49 PM
guttedEF's Avatar
All I've got is a bone stock 1st Gen B16 w/ LSD, with a K&N drop-in and a Thermal Exhaust. There are lots of factors that come into play..
Old Mar 25, 2003 | 03:29 AM
USDM 4G VTEC's Avatar
14.2's its a lil hard to beleive too...
i seen a EG HB with ITR engine run 14.00....
a EF chasiis with a ITR should be into very high 13's
i personally have squeezzed the 15.4 with just a Z6 with I/H/E.... and MSD switch...
i know i can take her lower with VTEC map , tunning, and a 2.2 60'
anyways u running a 14.4.... u should do better.... get a clutch... and from there well see the big diff u going to make!
SlicksMH
May 1, 2007 04:59 PM
vr6chris
Oct 18, 2004 01:29 AM
ORcivicsi
May 3, 2004 04:00 AM
newsense
Sep 25, 2001 06:01 PM
