What makes oil turn black?
Old Mar 24, 2003 | 07:28 AM
577HondaPrelude's Avatar
Default What makes oil turn black?
Sooo.. what makes old oil black? It is little parts of your engine in the oil, like fine metal dust? Is it from the oil getting too hot? Is it from the heat cycles of going from cold to hot, back to cold over and over that make the oil change is some way? Or something else?
Just wondering what really makes oil go bad over time.
Old Mar 24, 2003 | 07:32 AM
Spade's Avatar
Default Re: What makes oil turn black? (57STS)
Heat
Old Mar 24, 2003 | 07:35 AM
da94ludesi's Avatar
Default Re: What makes oil turn black? (Spade)
its from the carbon deposits your engine makes when you burn gasoline. Dirt can also make it black. Black oil is common in older engines (100k+ miles) and its ok, it just means its doing its job....cleaning your engine
Old Mar 24, 2003 | 08:10 AM
Default Re: What makes oil turn black? (da94ludesi)
so it's from blow down gasses then. Thanks...
Old Mar 24, 2003 | 08:41 AM
tilt's Avatar
put a lighter to some oil. give it enough time and it will turn dark.
Old Mar 24, 2003 | 08:47 AM
LS-hatch's Avatar
Default Re: What makes oil turn black? (tilt)
black paint will turn it black too.
Old Mar 24, 2003 | 11:55 AM
ejprimo's Avatar
Default Re: What makes oil turn black? (LS-hatch)
if your oil doesnt turn black then your motor oil isnt doing it job cleaning the inside of the motor.
meanshyguy
Mar 10, 2009 05:07 AM
alotawatts
Nov 27, 2004 12:01 PM
peacexisxfree
Sep 22, 2004 06:36 PM
91CivicSi
Nov 20, 2002 01:46 AM
