could a bad O2 cause weird idle?
Old Mar 24, 2003 | 06:54 AM
IloveNewt's Avatar
Default could a bad O2 cause weird idle?
It bounces from like 500-2000. Could a bad o2 sensor cause this?
Old Mar 24, 2003 | 06:59 AM
NXLude's Avatar
Default Re: could a bad O2 cause weird idle? (MordecaiPSI)
Yes it could....but if it were O2 then you would experience a slurry of other problem throughout the powerband
Old Mar 24, 2003 | 07:12 AM
RAB's Avatar
RAB
Default Re: could a bad O2 cause weird idle? (NXLude)
No, a bad O2 sensor would not cause you idle it jump around as you say its doing. I just had a bad O2 sensor for about 2 weeks and never got that symptom. The only way to determine if you have a bad O2 sensor is to pull the code from a CEL.
Old Mar 24, 2003 | 07:13 AM
IloveNewt's Avatar
yea my EGT's were readin that it was going either really rich or really lean. (before the guage died on me).
Man, i really hope the o2 is the prob, cause if it isnt i dont know where else to look.
Old Mar 24, 2003 | 07:23 AM
NXLude's Avatar
Default Re: could a bad O2 cause weird idle? (RAB)
Not to argue, but I had a O2 sensor go bad on my other car a month or so back and it screwed my idle all up.....but there were several other problems too, so i only assumed that it was a factor....if its only his idle fluctuatin then it isnt an o2, but if he has other symptoms it could be a problem.....
Old Mar 24, 2003 | 07:29 AM
RAB's Avatar
RAB
Yeah don't wanna start and retard argument about silly O2 sensors. Its that I was driving around with a fried one for about 2 weeks and had no problems with the idle. However the car didn't seem to drive normal. I contribute that to the fact that the O2 sensor adjust the a/f ratio when driving in closed loop, or city driving narrow throttle, not WTO.
Old Mar 24, 2003 | 07:36 AM
Elkins911's Avatar
this o2 bullshit again. and i agree that the o2 wont cause an idle problem.
the idle problem could be caused by a bunch of things. it sounds like you have a vaccum leak of some type. check hoses to see if you have any broken ones.... or you can crab carb cleaner and spray it all over hoses or places that could be leaking, if the car smooths out and almost dies then you probably found your leak.
you could also have a weak motor. whats the milage? might not be getting a nice clean spark.... voltage drops through out the car.... you fans could be turning on and off... as you can see, it could be a number of things. check the vaccum first.
Old Mar 24, 2003 | 08:22 AM
da94ludesi's Avatar
Default Re: could a bad O2 cause weird idle? (Elkins911)
also.....the exact air fuel ratio is determined by the ecu in until the o2 sensor is heated up to temperature, which takes i believe 5-10 minutes?
Old Mar 24, 2003 | 10:40 AM
sharkcohen's Avatar
Default Re: could a bad O2 cause weird idle? (da94ludesi)
Well, the ecu runs the engine richer (open loop) during sensor warmup, which takes a little over a minute. The ecu doesn't know anything about a/f.
[Modified by sharkcohen, 7:42 PM 3/24/2003]
Old Mar 24, 2003 | 11:50 AM
Elkins911's Avatar
Default Re: could a bad O2 cause weird idle? (sharkcohen)
lets not start this again... lets show him the other o2 sensor posts with all this crap if we just going to repost!
Old Mar 24, 2003 | 12:53 PM
sharkcohen's Avatar
Start what? If I see something that is technically incorrect, I am going to correct it. This IS a technical board.
chasmataz
Honda S2000
Sep 2, 2009 03:53 PM
jayman3.0
Feb 3, 2008 05:07 PM
Jayboy
13
Jun 19, 2005 12:29 AM
youngvedder
Oct 24, 2004 12:42 PM
VTC_CiViC
Jul 8, 2002 12:03 PM
