Sunroof In my 91 DX Hatch
Old Mar 24, 2003 | 06:40 AM
WindyIce's Avatar
Default Sunroof In my 91 DX Hatch
I have been wanting to put a sunroof in my hatch for a while but I don't know which one to pick up from the junk yard??? I don't like the Si Sunroof looks for my car and I was wondering if I could put in a intergra sunroof or something else. I just want a moon roof and have the ability to manually pop it up or if it is possible maybe even get a electronic one that I could wire up to my hatch.
Thanx
Windy
Old Mar 24, 2003 | 06:41 AM
Louie B.'s Avatar
Default Re: Sunroof In my 91 DX Hatch (WindyIce)
http://www.street-beat.com/slidragtop351.html
Old Mar 24, 2003 | 08:05 AM
WindyIce's Avatar
Default Re: Sunroof In my 91 DX Hatch (thumpu77)
I don't want a rag top but thanx for the though.
Old Mar 24, 2003 | 08:12 AM
WuShu's Avatar
New User
I have a 1989 hb sunroof with the complete assembly and everything you would need for sale at the moment. Im sure all youd have to do is cut the roof out and make a couple modifications. If your interested you can pm me, i could take some pics of how the roof mounts and how everything is so you could have an ide on how to go from there.
Adam F's Avatar
my bad read the post to fast
[Modified by Proelite103, 11:24 AM 3/24/2003]
Old Mar 24, 2003 | 08:18 AM
WuShu's Avatar
New User
Default Re: Sunroof In my 91 DX Hatch (Proelite103)
"you need to get one from a CRX because it opens on top of the car. The roof is to short for it to open inside the car."
not sure but from his post im guessing he has a hb.
HB sunroof will not fit a crx and vice versa, the roof shape is totallly diff.
Old Mar 24, 2003 | 09:51 AM
45psi's Avatar
Default Re: Sunroof In my 91 DX Hatch (HondaCRX)
you can use a 92-95 ex/si sunroof. they both open on top. cutting, welding, repainting required.
Old Mar 24, 2003 | 01:01 PM
b1reed's Avatar
Default Re: Sunroof In my 91 DX Hatch (45psi)
ill throw in my 2 cents.... i say just get a simple flip up one it will be the easiest its basically cut a hole in the roof put it in and put the ring on the underside and your done. you do have to figure somthin out for the head liner. at my local junkyard there is a hatch with a simple pop open sun roof im sure its aftermarket but its fits very nicely and has a big trim ring inside so you wont have to mess much with you head liner. i have a 91 acclaim sunroof in my car currently and it worked well its matched up good. let me know if you would like that one out of that hatch at the junkyard i can get it for you. im me you are intrested
ef-hatchcrap
Dec 15, 2005 09:43 AM
DaFredsta
Nov 4, 2004 02:19 PM
Alcoholic93Integra
Apr 7, 2003 09:29 PM
