The "right" way to break-in the engine = run it as hard as can be for seal tight?
Old Mar 23, 2003 | 09:56 PM
nEoMuGen's Avatar
Default The "right" way to break-in the engine = run it as hard as can be for seal tight?
http://www.mototuneusa.com/break_in_secrets.htm
Yay or Nay ?
[Modified by nEoMuGen, 1:56 AM 3/24/2003]
Old Mar 24, 2003 | 12:52 AM
WundedSaint's Avatar
Default Re: The "right" way to break-in the engine = run it as hard as can be for seal tight? (nEoMuGen)
The stuff he's stating is quite misleading, I'd definately say nay. Automotive engineers know more than this guy. He's just b.s.ing so people will give him attention.
Old Mar 24, 2003 | 01:06 AM
Josho_17's Avatar
Default Re: The "right" way to break-in the engine = run it as hard as can be for seal tight? (WundedSaint)
the guy who wrote it sounds like a host of an infomertial or something, i wouldn't follow that *** clowns advice.
Old Mar 24, 2003 | 01:48 AM
senpai's Avatar
You know what though? Hastings (the popular manufacturer of most piston rings) recommends a similar break-in.
Does Hastings NOT knwo what they are doing as well?
http://www.hastingsmfg.com/Service%2..._procedure.htm
Old Mar 24, 2003 | 03:13 AM
CRXSi90's Avatar
The street break in he showed wasn't really hard running, just a varying of the rpms. I agree that you should run it up and down the rpm range while there is a load on it. Don't be too rough on it, but don't be too nice.
(no, of course I don't have any real-world experience with this)
Old Mar 24, 2003 | 05:46 AM
jolt-tsp's Avatar
I'd have to say no go. I would never do that to my own car. You do want to run it over the entire rpm band during break in, but it should be done progressively and lightly. Also, I'd have to say running it too light is bad for the engine too.
Old Mar 24, 2003 | 06:14 AM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
Default Re: The "right" way to break-in the engine = run it as hard as can be for seal tight? (Josho_17)
*shrug* it's been talked about many times before and people have credited him.
he wouldn't make that huge page and test with a BRAND NEW bike just to screw people over.
Old Mar 24, 2003 | 07:09 AM
liquid51's Avatar
Default Re: The "right" way to break-in the engine = run it as hard as can be for seal tight? (dLo GSR)
I don't have any break in experience, but I can see how what he is saying makes sense. What I would like to see is a write up from someone who supports the manufacturer's break-in method so I could compare to two (and why the manufacturer suggests what they do. longer engine life=decreased sales???).
Old Mar 24, 2003 | 08:58 AM
LS-hatch's Avatar
Default Re: The "right" way to break-in the engine = run it as hard as can be for seal tight? (CRXSi90)
That is exactly what he is saying to do. You cant be too nice to it or the rings will NOT seal properly. If you follow what he is saying you will get a much nicer seal, I know from second hand experience (a friends engine). He has a v8 5.0 mustang and has tried both methods, once after a full rebuild and once after a broken valve. The harder break in method described on that page is almost exactly the method he used. After he broke the valve and tore it all down he noticed that the pistons, rings, and walls all looked exactly like they were supposed to unlike before when he had used a softer break-in like the factory suggests (when he still didnt know much as he put it). the softer break-in turned out much worse I am told. I wasn't around to see the first tear down but another person I talked to that was there for both also said that there was a noticable difference in quality.
cliff notes: that page is 100% correct, follow his method
Old Mar 24, 2003 | 12:51 PM
itr537's Avatar
Default Re: The "right" way to break-in the engine = run it as hard as can be for seal tight? (LS-hatch)
i broke mine in slowly last time and after three months blew piston # 4 i was scard to open it up at first took easy revving every so often up to 1000k....guys rebuilding my engine told me to drive it hard and now i read this so i guess ill be trying out this method...if im at the expo i guess it worked...hahahaha i guess ill drive the car like i stole it......
[Modified by itr537, 4:52 PM 3/24/2003]
Old Mar 24, 2003 | 02:33 PM
altoid's Avatar
Default Re: The "right" way to break-in the engine = run it as hard as can be for seal tight? (itr537)
what i don't get though is what he says about 5 or 10 lbs of pressure holding against all that combustion and how the rings don't do that much. I believe that they do a hell of a lot. perpendicular engeries don't affect each other whatsoever, so if honda wanted to they could make rings with 1/8 of a pound of pressure against the walls and the rings would be more prone to fail because of vibration than because of the constant combustion. what do you guys think?
Old Mar 24, 2003 | 02:46 PM
MikeMAN's Avatar
i say "yay!"
mike
Old Mar 24, 2003 | 03:50 PM
TREVER's Avatar
Default Re: The "right" way to break-in the engine = run it as hard as can be for seal tight? (MikeMAN)
I've had much better luck with a more agressive break in. This time I ran it to about 6k and used about 0-60% throttle for 200 miles. Then straight to 9500 100% throttle. It hasn't burnt any oil and the compression test was 320psi on all cylinders.
Old Mar 24, 2003 | 09:47 PM
LS-hatch's Avatar
Default Re: The "right" way to break-in the engine = run it as hard as can be for seal tight? (TREVER)
I would highly suggest changing the oil after like 20-30 miles as he mentions in there. It will look like its been used for 3000 miles when it comes out.
tom@yoparts.com
May 5, 2008 06:09 PM
HS2G
10
Apr 20, 2004 11:38 AM
Sonny
Jul 18, 2002 11:59 AM
PrecisionH23a
Jun 30, 2002 08:52 PM
slo95cx
May 27, 2002 01:32 PM
