Todays Noob question Gsr springs fit ef?
Old Mar 23, 2003 | 08:04 PM
Audipwr1's Avatar
Default Todays Noob question Gsr springs fit ef?
I looked over on kybs site and noticed the rear struts are identical on the 94-99 gsr as they are on our cars (91 civic for me)
I have a set of H&R springs for a gsr kicking around, can I use the fronts and backs on my civic?
Old Mar 23, 2003 | 08:05 PM
joshwhe's Avatar
Default Re: Todays Noob question Gsr springs fit ef? (Audipwr1)
i think that the springs for the gsr are longer... i know for the 2nd gen teg they are
Old Mar 23, 2003 | 08:29 PM
Cory man's Avatar
Default Re: Todays Noob question Gsr springs fit ef? (joshwhe)
Along time ago I compared a set of Eibach springs for a 94 gsr to the stock si hb springs. The gsr springs had a wider circumference than the si springs. Im sure that someone has made them work though. hth
Old Mar 23, 2003 | 08:54 PM
Adam F's Avatar
they wont fit properly
Old Mar 24, 2003 | 02:12 AM
ThatRicerDaniel's Avatar
yes they will fit.
Old Mar 24, 2003 | 06:06 AM
Audipwr1's Avatar
Default Re: Todays Noob question Gsr springs fit ef? (NitrousDreamz)
the rears will fit that is for sure (exact same struts)
has anyone used the fronts?
Old Mar 24, 2003 | 07:33 AM
TurboFryBox's Avatar
The fronts won't fit on the stock shock. You will have to get shocks for a 92-up. Then you will be all set.
Travis
[Modified by TurboFryBox, 4:53 PM 3/24/2003]
Old Mar 24, 2003 | 08:14 AM
Audipwr1's Avatar
Default Re: Todays Noob question Gsr springs fit ef? (TurboFryBox)
so then i cannot use ground controls off of a dc2 teg then?
arg, this **** is too confusing, they should have the same id of 2.5inches
Old Mar 24, 2003 | 08:45 AM
slowpokesi's Avatar
i have them on my rex,
they will fit, but you have to use shocks off a 92-95 civic, and you need the front shock forks.
Old Mar 24, 2003 | 09:08 AM
Audipwr1's Avatar
Default Re: Todays Noob question Gsr springs fit ef? (slowpokesi)
I am running civic si knuckles/calipers, so what i would need then is to just get the front forks? what should i pay for those? is it a difficult switchover?
Old Mar 24, 2003 | 09:26 AM
All you should need is the shocks. They should mount to your forks. the only thing different on them is how they are designed where the spring perches, they are oh so close to the same.
Travis
Old Mar 24, 2003 | 09:28 AM
Audipwr1's Avatar
so i can just order up a set of kyb agxs for a 92-96 civic and throw the Ground controls for the same generation right on there?
Please be sure this is a 500 dollar try
Old Mar 24, 2003 | 12:31 PM
Audipwr1's Avatar
comon people someone is running 92 civic front shocks, what have u done to make it happen
alignment
camber
etc
Old Mar 24, 2003 | 03:04 PM
Audipwr1's Avatar
ok ill pay for information
i need someone who has done it, and what they did and what issues they found, alignment camber etc
Old Mar 24, 2003 | 03:28 PM
whats the problem ..????? put the springs on the car .. civic all gen integra all gen dont matter all the same .. they all fit just put them on .. it only takes an hour if you dont like the ride hieght take them off. not a big deal.
Old Mar 24, 2003 | 03:29 PM
Audipwr1's Avatar
I would like to run the dc2 integra shocks and ground controls on the ef, i need to know what is involved to switch the front end to accept that
thanks guys I appreciate it
Old Mar 24, 2003 | 03:33 PM
mr. carpenter's Avatar
this is mostly to do w/the shocks but also about the problem i encountered w/the front forkshttp
https://honda-tech.com/zerothread?id=450851
[Modified by mr. carpenter, 12:34 AM 3/25/2003]
Old Mar 24, 2003 | 03:36 PM
whats involved? jack up the car and change them.. do you need help lowering the car?
Old Mar 24, 2003 | 07:06 PM
Audipwr1's Avatar
so i guess i should just go with an entire ef system
not worth screwing around
Old Mar 24, 2003 | 07:33 PM
slowpokesi's Avatar
i told you what i had to do
i got gsr integra springs, and the shocks came off of a 95 del sol, i had to use the 95 sol forks as well, as far as i know the delsol and eg hatch are the same.
b18a1hatch
Nov 2, 2009 05:17 PM
Mr_Moos
Oct 10, 2008 04:16 AM
blackbb4lude
Jul 5, 2007 04:33 PM
ebelp
Jun 11, 2003 02:24 PM
