Quick question. Are EG springs the same length as EF springs?
Old Mar 23, 2003 | 06:12 PM
Steve91's Avatar
Default Quick question. Are EG springs the same length as EF springs?
I got a set of Eibach's for a 94. If I put them on a crx, will it lower it the same amount as EF EIbach springs would?
Old Mar 23, 2003 | 06:42 PM
Agent Daimon's Avatar
Default Re: Quick question. Are EG springs the same length as EF springs? (Steve91)
no it wont.. dont do it..sell it and get some ef lowering springs..trust me
Old Mar 23, 2003 | 07:30 PM
Count Blah's Avatar
From: A place where stupidity runs rampant aka NorCal
Im running EG kg/mm springs on my CRX. To sum it up, on Koni Yellows, the kg/mms on the bottom perch is the same as eibach sportlines on the top perch.
And a picture:
hth
-Todd
Old Mar 23, 2003 | 08:45 PM
Steve91's Avatar
Default Re: Quick question. Are EG springs the same length as EF springs? (Count Blah)
Exactly what springs are those in the picture?
Old Mar 23, 2003 | 09:16 PM
Adam F's Avatar
Default Re: Quick question. Are EG springs the same length as EF springs? (Agent Daimon)
Just get the right springs for your car!
Old Mar 23, 2003 | 09:28 PM
Count Blah's Avatar
The blue ones are kg/mm SR21 Supersports. The lower ones are Eibach Sportlines.
The supposed drop on the kg/mms are 1.8" on an EG. If i would have put them on stock shocks, or the top koni perch, I would have about a 1" drop. The lower Koni perch allows me to go 1" lower, so I have right under a 2" drop at the moment.
-Todd
Old Mar 24, 2003 | 02:18 AM
ThatRicerDaniel's Avatar
they will fit but the OBVIOUS POINT here is the weight of the car. just cut em and put them on.
Old Mar 24, 2003 | 05:45 AM
89civicdx's Avatar
Default Re: Quick question. Are EG springs the same length as EF springs? (NitrousDreamz)
NO! they are not the same the EG front springs are taller so if you use a eg lowering spring in your car it will sit higher then its intended lowering.
Old Mar 24, 2003 | 07:14 AM
BERT-O's Avatar
Default Re: Quick question. Are EG springs the same length as EF springs? (89civicdx)
I second that
Old Mar 24, 2003 | 07:20 AM
Steve91's Avatar
Default Re: Quick question. Are EG springs the same length as EF springs? (Proelite103)
Thanks for the info. Their not for my car, someone with an EF was interested in buying them from me and asked if they would work.
Old Mar 24, 2003 | 07:23 AM
Count Blah's Avatar
Incorrect, they are not taller (as illustrated in the picture above, EG springs on top, ED springs on bottom). The spring rates, however, are stiffer, so the spring will not compress as much as the softer rate ones will. If you have Koni Yellows on your car with the adjustable perch, then you will be fine with EG springs, and will in fact provide a noticable improvement in handling due to the stiffer spring rates. Anyone interested in more information on this please feel free to PM me. There is no reason to keep spreading mis-information about this subject.
-Todd
Old Mar 24, 2003 | 03:33 PM
hmm not longer ~~ why would the spring rates be stiffer?? uhh maybe cuz the weight of the car. just cut them and put them on ..
smokinloc
Jan 26, 2010 05:44 PM
Metal Head
Suspension & Brakes
Nov 25, 2006 09:57 AM
dlric
Jan 20, 2005 02:34 PM
MulletManRockStar
Dec 21, 2004 01:48 PM
