Koni Yellows install question
Old Mar 23, 2003 | 02:47 PM
CRXTSEE's Avatar
Default Koni Yellows install question
ok... so how the heck do i get a brake line bracket onto the Koni's? The shock I have (silver ) has the bracket WELDED on.... I don't see how I can re-use it. I don't know if the brake line bracket can be purchase seperately
http://www.imagestation.com/picture/...a/fc758481.jpg
Old Mar 23, 2003 | 05:56 PM
tylerdurden's Avatar
Default Re: Koni Yellows install question (CRXTSEE)
Have you called a dealer to confirm that you can't get the bracket separately from the shock? I would be surprised if you couldn't. Check that out, and if not then try to buy some off someone who put on a shock that has the bracket pre-installed.
I have to say that it is pretty cheap of Koni not to do that. Other similarly priced (and cheaper) shock have them custom made to your app. That was the biggest bitch when I installed my Yellows. Hope this helps.
Old Mar 23, 2003 | 06:16 PM
jasonb's Avatar
the bracket itself cannot be purchased seperately. The dealer only sells it with the OEM strut. So, either find a friend that has some laying around, or go to the junkyard and pic them up.
Old Mar 23, 2003 | 06:20 PM
CRXTSEE's Avatar
Default Re: Koni Yellows install question (jasonb)
....okay that helps..... so I assume the stock shocks have the brake bracket pressed (not welded) on? geez.... thanks Koni
Old Mar 23, 2003 | 06:52 PM
No, it isn't welded. Lube it up with something that penetrates, then tap it off with a screwdriver and hammer. It was a REAL bitch for me. Getting them on the Koni's after that was an even bigger frustration. I had to take it to a shop and have them grind material out of the inside of the bracket so it could slide far enough up the shock body to get the damper fork back on.
Old Apr 9, 2003 | 04:47 PM
Jay J's Avatar
Prince of Zamunda
here you go
Old Apr 9, 2003 | 06:56 PM
keithv's Avatar
Default Re: Koni Yellows install question (neuspeed)
i just used some zip ties to hold the brake line.
Old Apr 10, 2003 | 07:19 AM
Renegade's Avatar
Default Re: Koni Yellows install question (breaka_1_9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by breaka_1_9 &raquo;</TD></TR><TR><TD CLASS="quote">i just used some zip ties to hold the brake line.</TD></TR></TABLE>
crxsleeper210
Feb 17, 2008 01:40 PM
fast95se
Nov 2, 2006 06:38 AM
itsblue98
Apr 12, 2006 07:23 AM
SwiftTypeR
Jan 29, 2006 01:04 PM
tolnep
Jul 11, 2004 08:25 AM
