is this to many miles to go tubro
Miles dont matter, condition of the engine matter. Do a compression/leak down test. If the numbers are good, give the motor a once over to make sure everything is in good condition. Replace things that need replacing. Fix things that need fixing and you should be fine.
I wouldnt think that anything under 100k is too high, but it is the condition that matters. The bigger thing is that it is somewhat unlikely that unless you have serious wear on the motor that you will break a rod at that mileage and that is the biggest fear in my book. Just make sure to do the turbo system right and make sure you dont denotate(kills you everytime).
Charlie Moua
Dec 30, 2002 07:16 PM
b18tdelsol
Apr 17, 2002 10:34 PM
