anyone know what a DSM wg boost level is set at
Old Mar 22, 2003 | 06:45 PM
Boostless97Lude
Guest
Posts: n/a
Default anyone know what a DSM wg boost level is set at
i could possibly be picking up a DSM turbo cheap, and i am thinking of putting it on my soon2be B20 powered del Sol, just want to make sure i don't push way to much boost or anything
Old Mar 22, 2003 | 07:13 PM
DeepSi's Avatar
Default Re: anyone know what a DSM wg boost level is set at (EX-Boosted97Lude)
most DSM turbos boost between 15-18 psi stock, so that is what i am assuming the stock wastegate is set too
Old Mar 22, 2003 | 07:19 PM
UberTeg's Avatar
Default Re: anyone know what a DSM wg boost level is set at (DeepSi)
What dsm is this? Eclipse/talons are 12psi with the STOCK ebc... but if u just use the wastegate, they are set at 8psi.
Old Mar 22, 2003 | 07:53 PM
DeepSi's Avatar
Default Re: anyone know what a DSM wg boost level is set at (UberTeg)
i just rechecked it is 11.5 psi stock. His intake system and a few tweaks he has allows him to go to 15 psi and spike all the way up to 18 psi sometimes.
[Modified by DeepSi, 10:59 PM 3/22/2003]
Old Mar 22, 2003 | 09:31 PM
DD_JonnyLee's Avatar
depends on what year eclipse, 89-94 8-10lbs, 96-99 15-18lbs
Old Mar 22, 2003 | 09:37 PM
turbod16y8's Avatar
Default Re: anyone know what a DSM wg boost level is set at (TrboGSR)
its 8 psi
Old Mar 22, 2003 | 09:39 PM
JalopySiR's Avatar
Default Re: anyone know what a DSM wg boost level is set at (turbod16y8)
He is correct, the wastegate is set to 8psi. The boost is electronically adjusted higher by the computer. Mechanically=8, electronically=11+(but who cares)
Old Mar 22, 2003 | 10:14 PM
UberTeg's Avatar
Default Re: anyone know what a DSM wg boost level is set at (JalopySiR)
wastegate is 8 (i have a t25 which is 96-99), ,and the solenoid takes it to 12psi, NOT higher. I rechecked htis with my dsm friend.
Old Mar 22, 2003 | 11:38 PM
untitled's Avatar
its 8 psi
superhatchbackbros
Jun 30, 2007 09:17 AM
94ta_lt1
Oct 4, 2004 10:09 PM
1.8T_EG
Sep 12, 2002 09:00 PM
4gvtec
May 21, 2002 12:10 AM
teg90rs
Dec 6, 2001 03:48 PM
