Calling all Swaps w/ A/C.........Turbo?????
I am contimplating a B series swap into my CRX or 89 hatch but I want to keep the A/C. I know I can get the bracket from hasport but my dilema is that I am not sure if I can pull it off with a turbo installed. Right now the hatch has a D16Z6 turboed w/ the greddy kit and A/C and that is tight fitting.
Has or does anyone have a B series swap w/ A/C and turboed?
Cars w/ A/C, can you post pics so that I can get an idea of available space.
I am serious so any ideas will be helpfull and appriciated. I plan on using a HKS B series manifold with the Greddy turbo retaining the cast 90 degree exhaust outlet as I feel this should give me max clearance of the compressor and radiator.
AC man, who cares about AC too much hasle if you ask me!
even lately its hitting high 80's
Here is a picture of my CRVTEC in my crx w/ HASport mount kit, and A/C bracket.
That was when i first finished the swap.
I actually did my entire crvtec swap without disconnecting any A/C lines.
Since R-12 is very expensive, I was not looking foward to discharging my perfectly working A/C system, so I just did the swap without unhooking anything, worked very well, just was a pain in the *** to work around at times. My A/C fan did NOT fit, there wasnt enough room, regardless, my single fan turns on if i turn my A/C on, and it also turns on if the cars temp gets too hot, so i really have no need for 2 fans.
[Modified by irev210, 7:57 PM 3/23/2003]
No it is not all that hot in PA but this is going to be the dayly driver and in the winter A/C helps defrost/defog the windows. Helps alot. And it is also a braging thing. To say that ones car is not stipped is one thing, but to have it all there as it came stock (all the bells and whistles) and kick a gutted car's or a muscle car's *** puts a smile on ones face. Right now the hatch, which is a SI, is turboed, has A/C, full interior, and 17" wheels and I never use the excuse that if the car was lighter I would have beat you. BTW it's best time is 13.39 @105.9 in the stated form above. Never got to run on slicks.
I want the turbo B series swap in the CRX which is lighter and i will have more power to start. In other words the goal is to break 11's w/ a street car (on slicks) that is a true complete steet car.
Thanks for the pics
Thanks for the pics
I have a b16 swap and had the Hasport bracket with both fans and it worked fine, I don't see how you can have turbo, just test fitting my turbo kit there is no way to make it work especialy if you run an innercooler.
camoxiong
Aug 14, 2014 01:51 PM
B16Civic93
Mar 28, 2009 06:25 PM
