GSR sounds raspy when the WG opens? because open dump tube?
Old Mar 22, 2003 | 06:00 PM
Diego Boost's Avatar
Default GSR sounds raspy when the WG opens? because open dump tube?
I notice that when my wastegate opens and I'm in vtec that my GSR sounds very raspy. Is this because I'm running an open end dump tube? How can I fix it?
Old Mar 22, 2003 | 06:06 PM
Smashback's Avatar
Default Re: GSR sounds raspy when the WG opens? because open dump tube? (Diego Boost)
Run closed loop. It's the only way to kill that lawnmower wg noise.
Old Mar 22, 2003 | 06:08 PM
Default Re: GSR sounds raspy when the WG opens? because open dump tube? (Hatchblack)
Is there a noticeable difference in performance?
Old Mar 22, 2003 | 06:20 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
minimum distance for the dump tube to run separately is 18", before joining the main exhaust.
stan
Old Mar 22, 2003 | 06:37 PM
Default Re: GSR sounds raspy when the WG opens? because open dump tube? (jz)
At the risk of sounding dumb, how does one go about "closing the loop" ?
Old Mar 22, 2003 | 06:42 PM
you rejoin the bump tube into the main exhaust.
18" down the road.
stan
Old Mar 22, 2003 | 06:43 PM
Default Re: GSR sounds raspy when the WG opens? because open dump tube? (90crxsi)
18" down the road.
stan
Thanks! Now I have somthing to do tomorrow
Old Mar 22, 2003 | 07:02 PM
Has anyone ever tried attaching a "mini" muffler to the end of the dunp tube? I wonder if that would quiet it down a bit?
Old Mar 22, 2003 | 08:20 PM
BoostedSi's Avatar
if you want it quiet, just route it back in the exhaust.
I think my open dump tube sounds good. Doesnt sound like a lownmower to me...i like it
RedR
Aug 26, 2006 11:38 PM
radio1global
Aug 12, 2004 12:56 AM
SIK IN DA HED
May 25, 2002 11:16 AM
92HB_HB
May 15, 2002 04:48 PM
Damon B.
Nov 27, 2001 01:25 PM
