axle help
Old Mar 22, 2003 | 04:38 PM
NVMYSi's Avatar
Default axle help
How do I get the drivers side axle to come out? I have everything unhooked already. Also on my passengers side I have been trying to get the lca to come off the ball joint with the hammer method, no luck. Do i need to buy a ball joint sperater? This is on a 00 Si.
Old Mar 22, 2003 | 05:16 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: axle help (NVMYSi)
i hit the lower control arm really hard, never failed me. a ball joint separator will tear the boot, but yes it will work.
Old Mar 22, 2003 | 06:41 PM
NVMYSi's Avatar
Default Re: axle help (boostedcivicsir)
well, i already damaged the boot from a wild swing with the BFH.... , how will the ball joint fork damage the boot? Can somebody explain how it works.
Old Mar 22, 2003 | 11:24 PM
tilt's Avatar
dont get a ball joint seperator. instead, wedge a bar(like the end of a ratchet) between the knuckle and lower control arm. You can increase the gap so the bar will fit by jacking up on the rotor. Once you have the bar stuck between, remove the jack, and jump on top of the rotor and that should break it free.
White_EG1
22
May 21, 2018 10:20 AM
Alcatrax30
Nov 9, 2014 05:38 AM
C_Rock77
Aug 27, 2008 11:19 AM
Vp Special K
17
Jan 6, 2004 02:08 PM
GruvyTune
Jul 22, 2002 10:01 AM
