no sprark
Old Mar 22, 2003 | 01:57 PM
joshwhe's Avatar
Default no sprark
ive been having problems with my b18a1 swap... i have fuel now but still no spark... all my grounds check out to be ok same with all my fuses.......... it seems like either no power to the dizzy or ecu.. i have a aftermarket tach when i crank it it stays on 0 so that leads me to think that theres no power ......or ign output. so i dont know any help would be great
Old Mar 22, 2003 | 02:50 PM
Malgerus's Avatar
Default Re: no sprark (joshwhe)
ignitor?
Old Mar 22, 2003 | 02:55 PM
joshwhe's Avatar
Default Re: no sprark (Mr. S)
i put a new ignitor and coil in last nite...... thats waht i thought too. thanks for your input... anyother ideas?
Old Mar 22, 2003 | 02:57 PM
Malgerus's Avatar
Does the ECU light come on?
Old Mar 22, 2003 | 03:33 PM
joshwhe's Avatar
theres no cel or code on the ecu
Old Mar 22, 2003 | 03:53 PM
PhatOptimo's Avatar
check the coil with a multi-meter
Old Mar 22, 2003 | 09:55 PM
joshwhe's Avatar
Default Re: no sprark (Phat_Optimo)
i put a new coil in too...thanks any more ideas?
Old Mar 23, 2003 | 02:00 PM
joshwhe's Avatar
redid all grounds and new cap.. runs now. thanks for all the help
Old Mar 23, 2003 | 02:30 PM
AbaZ's Avatar
What kinda car did you do the swap in?
Did you have to repin the distributor wires at all?
sometimes people mix up the 2 white wires, that look identicle, you could try swapping them around.
Jeff
Old Mar 23, 2003 | 07:12 PM
joshwhe's Avatar
Default Re: no sprark (AbaZ)
yeah its a b18a1 into a 89 dx .... i did th mpfi wires awhile ago when i did the mpfi swap ran great....... the problem ended up being a bad cap. now im faced with a new problem the car doesnt seem to rev very high nore hit the rev limiter at all.......... it seems very slow also... i have no ecu codes also..
joshwhe's Avatar
thanks for the help any ideas on the rev and no power thing????
Old Mar 23, 2003 | 07:43 PM
AbaZ's Avatar
Do you have another distributor you can test on the car? It wont let you rev?
Old Mar 23, 2003 | 07:50 PM
joshwhe's Avatar
i dont have another dizzzy,.,,,... ah yeah it doesnt seem to rev high at all and theres no rev limiter either my tach is not working so i dont know how high its going prob not high enough to hit the limiter.... plus its really slow so i m very stumped
Old Mar 23, 2003 | 07:54 PM
joshwhe's Avatar
seems like somthing is holding it back... its like there is no power.
bfpicard
Sep 21, 2013 04:42 AM
civicb1812345
17
Aug 21, 2013 09:37 PM
arizpe18
15
Sep 29, 2012 05:32 PM
Gumbey75
Oct 4, 2010 11:53 AM
huge230
Oct 2, 2005 09:59 PM
