What is your EGT at wide open throttle???
Old Mar 22, 2003 | 10:50 AM
turbo Si's Avatar
Default What is your EGT at wide open throttle???
Mine seems to hit about 1600, then I let off. I thought 1500 or more is boiling point.
Old Mar 22, 2003 | 11:20 AM
MachAF's Avatar
Default Re: What is your EGT at wide open throttle??? (turbo Si)
1600 is too hot. Your running too lean. Add more fuel.
Old Mar 22, 2003 | 11:40 AM
turbo Si's Avatar
Default Re: What is your EGT at wide open throttle??? (machaf)
Yeah your right. What else can I do to lower my EGT? Can I reduce the gap on my plug, or even go to a colder plug. My heat range now is 7.
Old Mar 22, 2003 | 11:53 AM
Andrew 825SM's Avatar
Never hits above 800 degrees celsius.
Old Mar 22, 2003 | 12:01 PM
inspyral's Avatar
Default Re: What is your EGT at wide open throttle??? (Andrew 825SM)
mine is btween 7-800C
Old Mar 22, 2003 | 12:08 PM
turbo Si's Avatar
Default Re: What is your EGT at wide open throttle??? (inspyral)
Yall are running Greddy, or Apexi? I'm running Autometer. It goes by Farenheit!
Old Mar 22, 2003 | 02:01 PM
b18cTurbo's Avatar
not only lean conditon will raise your egt but to much retard will also raise your egt
Old Mar 22, 2003 | 02:44 PM
turbo Si's Avatar
Default Re: What is your EGT at wide open throttle??? (C5turbo)
Really.............is that for sure?
Old Mar 22, 2003 | 03:08 PM
PrecisionH23a's Avatar
ditto
Old Mar 22, 2003 | 03:13 PM
turbo Si's Avatar
Default Re: What is your EGT at wide open throttle??? (GudeH23a)
Yeah, but what about Farenheit????????
Old Mar 22, 2003 | 03:15 PM
Oh cmon now! stop being lazy!
How To Convert Temperatures
Fahrenheit to Celsius
1. Subtract 32 from degrees Fahrenheit
2. Multiply by 5
3. Divide by 9
Celsius to Fahrenheit
1. Multiply degrees Celcius by 9
2. Divide by 5
3. Add 32
or...
http://www.wbuf.noaa.gov/tempfc.htm
Old Mar 22, 2003 | 03:20 PM
philo's Avatar
If your fuel is anywhere close to 12:1, then 1600 is way too high. We have similar setups and I run 1200f at WOT.
If you over retard you timing you will raise your EGT. That is a pretty common tuning error when running high boost.
What did you end up putting down today?
Old Mar 22, 2003 | 11:49 PM
TurboDANDEE's Avatar
Default Re: What is your EGT at wide open throttle??? (philo)
mine is 700 celcius at WOT, i've never seen 800, only when boosting on 5th gear.
Old Mar 23, 2003 | 12:23 AM
boostaholic's Avatar
~1200 F, 5th gear will get a little hotter
Running too much retard can also give you a false reading of lean or rich because the fuel doesn't have enough time to burn inside the chamber and will finish burning off in the exhaust giving you a higher EGT while your a/f may indicate rich.
Old Mar 26, 2003 | 02:54 PM
93turbolude's Avatar
well then break out the chemistry books and do the math to convert, if you can put in the guage, you can do the math....... or if you're lazy, buy another guage
Oleg
Jul 23, 2006 11:27 PM
goofball123321
Oct 15, 2003 01:08 AM
speedymon
Oct 8, 2003 10:17 AM
CiViC SiR
Jan 29, 2003 01:52 PM
RaVAGE00
Sep 26, 2001 11:42 AM
