gsr intake manifold?
i have a b18c1 and i'm using a chipped p28 and i know that the p28 is not capable of controlling the butterfly valve of the IM. so my question is which runners of the manifold am i using all the time???? the short ones or the long ones?
Your secondaries are stuck open. This means you lose about 10 lb. ft. of torque on the low end.
Well if i'm not wrong, the longer, upper runners are the ones your using.
Shorter runners provide better airflow for top RPM-band power, but give up a little torque on the bottom end. Using shorter runners would move the powerband of the engine up, shifting the torque and horsepower curve. (hope that helps you)
-not sure about the stock gsr mani question
TheCrimsonGhost666
Jun 6, 2010 08:42 AM
lalocivic
May 27, 2010 07:56 AM
