Highway CEL
Old Mar 22, 2003 | 04:48 AM
CapnChunk's Avatar
Default Highway CEL
I ran a search on this because I thought someone would have asked this before, but nothing came up.
The last two times I drove on the highway, within two minutes of hitting 70 I get a CEL. I pull over, check my fluids and smell for anything that smells like burning - but everything is ok. Turning off the car, even for 2 seconds, will fix the light. I don't get this when I just do some city driving. Anyone have an idea?
Old Mar 22, 2003 | 05:32 AM
markben151's Avatar
Default Re: Highway CEL (CapnChunk)
i get that same problem but i dont know how to fix it
Chiovnidca's Avatar
What code does it have stored?
Old Mar 22, 2003 | 05:44 AM
CapnChunk's Avatar
Default Re: Highway CEL (TurboD16Chiovnidca)
I'm not sure about the code - I'm about to check that out at Autozone or at my friends shop. Will it still have the code if the CEL isn't on? Like I said, turning off the car turns off the light.
Old Mar 22, 2003 | 06:15 AM
Chiovnidca's Avatar
Yes, it should hold the code.
Old Mar 23, 2003 | 07:04 AM
CapnChunk's Avatar
OK - so I did the wire thing and got a code 12. I looked it up and it's an EGR problem. The only thing that I can think of that would impact this is that I put on an AEM CAI. Is this a terrible CEL that I can't live with? Is there something I can readjust with the CAI to get this to go away? Thanks.
Old Mar 23, 2003 | 07:08 AM
niedejb's Avatar
The EGR system has nothing to do with the intake (unless you unplugger the EGR valve or one of its solenoids in the installation process).
If the plugs are all correct, I did a write up on disabling that system. Dont know if itll help (when I did it I didnt have a CEL on).
https://honda-tech.com/zerothread?id=442008
Old Mar 23, 2003 | 07:15 AM
Chiovnidca's Avatar
What year and model is it?
Old Mar 23, 2003 | 07:18 AM
CapnChunk's Avatar
My mistake - I always laugh at the people who forget to post that, then I do it myself. I guess I'm one of those people now.
I have a '94 EX.
Old Mar 23, 2003 | 07:33 AM
Chiovnidca's Avatar
I have a '94 EX.
I see several common problems on those causing a code 12. The EGR solenoid valve, the EGR valve and clogged EGR ports. You can check the EGR solenoid valve by applying power and ground to it to see if it clicks. (It's near the left shock tower.) If it does click, start the engine and energize the solenoid. Does the engine start to run real rough or stall, or does the idle drop only slightly or not at all?
jwagner
Engine Management and Tuning
Apr 8, 2012 07:38 PM
1251_ks
Honda Civic (2001 - 2005)
Oct 7, 2010 03:39 AM
slvrlude
Dec 27, 2008 02:50 PM
wilsel
Apr 15, 2005 05:18 AM
emanLS
Oct 20, 2003 01:15 PM
