Gas filter, Where is it located
Old Mar 21, 2003 | 04:13 PM
duppykiller1's Avatar
Default Gas filter, Where is it located
Lately I smell gas when the car is just turned off. I never changed the filter before. I just want to know where the gas filter located on a 90 civc si?
It also has 134,000 Km on it.
Old Mar 21, 2003 | 04:18 PM
Malgerus's Avatar
Default Re: Gas filter, Where is it located (duppykiller1)
Well I doubt the two are related, but...
the fuel filter is located beside the throttle body, and the intake tube. It has two lines going into it. Get a manual to guide you through the procedure.
[Modified by Mr. S, 5:18 PM 3/21/2003]
Old Mar 21, 2003 | 04:21 PM
Default Re: Gas filter, Where is it located (Mr. S)
Do you have any suggestion why it smells like gas after it is turned off?
Old Mar 21, 2003 | 04:25 PM
EG8R's Avatar
fuel leak maybe....
Old Mar 21, 2003 | 04:36 PM
broncoman74's Avatar
From: Northwest Hills of, CT., United States of America
Check around your fuel injectors where they enter. My ex had an 88 Prelude Si and hers leaked just like you are describing. It may not be the problem ,But at least you can say you checked. One more place to check should be your gas tank, It may be leaking which would also explain why you are smelling it when you are shutting of the car(sitting still). Hope this helps!
boostedefhatch
10
Feb 21, 2009 01:35 AM
04AccordEX
Jan 23, 2008 06:19 AM
Blamm!!
Feb 5, 2007 07:59 AM
moacsupreme
Jun 28, 2004 11:05 PM
4inspeed
Jan 18, 2004 12:20 AM
