no spark watsoever...
Old Mar 21, 2003 | 02:44 PM
sailor's Avatar
Default no spark watsoever...
hey peeps,
i need help please, i have a 97 accord lx 2.2 sohc, car has no spark watsoever, we changed the wires, coil, distributor, stil nothing. ecu is working fine. wat else could it be guys?
thanks,
mike
Old Mar 25, 2003 | 05:33 PM
acuratech's Avatar
Default Re: no spark watsoever... (sailor)
Check the ignitor. I think it is in the distributor as well on that one. These commonly go bad, and cause a no-spark condition.
Old Mar 25, 2003 | 05:42 PM
sailor's Avatar
Default Re: no spark watsoever... (acuratech)
i took it to the dealer to get a diag, they said its the starter???? tru???
Old Mar 25, 2003 | 05:57 PM
Kamin's Avatar
and your not getting spark?
hahaha never go to that dealer again.
Old Mar 25, 2003 | 06:08 PM
acuratech's Avatar
does the motor rotate over when the key is in the start position? if it just clicks then it could be starter or battery. if it does then it is either the ignitor or something like a main relay. get in the car shut the door, turn the hey to run, but dont hit the starter, and see if you hear a single click at the same time that the engine light goes off. If you hear the click, then the main relay is ok. In this case it will be the ignitor, or a fuse.
Old Mar 25, 2003 | 06:11 PM
sailor's Avatar
wel it was getin spark on and off last week, 1 day, the next couple days no spark.
took it to the dealer yesterday, they said they got spark, and its the starter thats dead. no click or nothing when i turn the key,batt is good because all the lights work and windows, radio.
Old Mar 25, 2003 | 06:12 PM
sailor's Avatar
wat fuse would this be that ur referrin to?
Old Mar 25, 2003 | 06:14 PM
Kamin's Avatar
hold on
its not turning over?
that has nothing to do with spark dude. if the battery is ok its probably the starter solenoid, try to start it and have someone gently tap it with a hammer.
Old Mar 25, 2003 | 06:37 PM
acuratech's Avatar
I think there is a starter relay fuse, just to be safe, check ALL fuses engine compartment, and the fuses under the hood. Fuses should always be checked first on any electrical issue.
Old Mar 27, 2003 | 07:10 AM
sailor's Avatar
yes i checked all the fuses, there fine. any way of checkin the coil /distributor? im totally stumped.
Old Mar 27, 2003 | 07:11 AM
sailor's Avatar
any way of checkin the ignitor?
Old Mar 27, 2003 | 11:53 AM
vtecvoodoo's Avatar
Future Texas Boy
borrow a distributor and install. That`s the easiest way. If it works, than you have narrowed it down to something in the distributot. Only takes 5 minutes to throw a new one on.
Old Mar 27, 2003 | 12:17 PM
Katman's Avatar
Are your spark plug wires going to the correct plug-in on the distributor?
Old Mar 31, 2003 | 05:47 AM
sailor's Avatar
Default Re: no spark watsoever... (Katman)
how do i test the ignitor?
Old Mar 31, 2003 | 10:36 AM
Katman's Avatar
just plug it in ....if the car starts then it works if it doesnt work, the car wont start or just plain runs like crap.....sometimes you'll get the flickering/wild tachometer needle effect too..
Old Mar 31, 2003 | 06:12 PM
sailor's Avatar
im askin how do i test the ignitor to c if its bad?
Old Mar 31, 2003 | 06:45 PM
aut0tek's Avatar
get a manual and a multimeter and check resistances for the ignitor test.
But if it won't turn over then the ignitor isn't the issue right now. get it to at least turn over (starter) then go from there.
Harry
[Modified by aut0tek, 10:46 PM 3/31/2003]
Old Apr 2, 2003 | 08:36 AM
sailor's Avatar
Default Re: no spark watsoever... (aut0tek)
car starts, but just doesnt turnover, ive performed tests on the ignitor, and coil , and also swapped distributors, everything is good in that aspect. where should i check next? relay? where is the main relay located on the 97accord lx 2.2no tec?
thanks,
j
Old Apr 2, 2003 | 10:16 AM
JimBlake's Avatar
car starts, but just doesnt turnover...
Maybe you're confusing us by saying it that way...
I always thought 'turning over' means that the starter is cranking the engine. Even without any fuel or spark, your starter should turn over the engine.
'Starting' sounds like it fires & runs.
Old Apr 2, 2003 | 10:20 AM
sailor2's Avatar
Default Re: no spark watsoever... (JimBlake)
cranks but doest start
deathmine
Sep 1, 2014 04:03 AM
dirrtybirdy
Mar 28, 2010 01:43 PM
chito_zan
34
Aug 23, 2004 10:56 PM
MetalKill
10
Jan 30, 2003 07:42 AM
HYBRIDGSiR
Nov 23, 2001 07:32 AM
