valve adjusting method
Old Mar 21, 2003 | 09:38 AM
b18prl's Avatar
Default valve adjusting method
what is the difference between taking valve lash from cam to rocker arm and valve stem to rocker arm?
Old Mar 25, 2003 | 09:02 AM
JimBlake's Avatar
Default Re: valve adjusting method (b18prl)
The clearance will be different depending on which place you measure. So you gotta be sure you know which one they mean when you read the amount of clearance. It probably depends on which one is easier to reach with a feeler gauge.
My '95 GS-R says to measure between the cam & the follower. I thought somebody said the SOHC engines call for the measurement at the valve stem, but check the shop manual for YOUR car.
Old Mar 26, 2003 | 11:21 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: valve adjusting method (JimBlake)
sohc's are valve tip to follower
tony_yang
Oct 13, 2010 08:12 PM
Blk_EJ1
Mar 30, 2007 01:02 PM
NA JDM GSR
Oct 17, 2006 10:50 PM
TurBoTeG
Jan 8, 2004 01:54 PM
95gsr
Apr 8, 2003 07:20 AM
