how to tell if fuel pump is going out?
Old Mar 21, 2003 | 07:38 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default how to tell if fuel pump is going out?
Does it make any kind of wierd noises or anything if the fuel pump is on its way out?
Old Mar 21, 2003 | 08:16 AM
Community Builder
Default Re: how to tell if fuel pump is going out? (PatrickGSR94)
I'm hearing a high pitched whine/hiss from mine, almost like alternator noise (I don't have any interior behind my front seats at the moment). Is this normal or should I be concerned?
Old Mar 21, 2003 | 09:07 AM
E-Rok's Avatar
EPIC TUNING
with no rear seats and a stock exhaust, you can easily hear the fuel pump. Its fine.
Old Mar 21, 2003 | 10:39 AM
tilt's Avatar
there's a test you can do. I dont know the specifics for it but basically you take the fuel line and put a cup to it and measure the flow. For n seconds there should be x volume of fuel. If you are less than normal specs (look it up in a manual) then you know your pump isnt performing how it should be.
Old Mar 25, 2003 | 04:08 AM
JimBlake's Avatar
Default Re: how to tell if fuel pump is going out? (tilt)
... measure the flow...
You can also measure the pressure - usually that's a test for the FPR, but if the pump can't keep the pressure high enough, you'll see that.
Old Mar 25, 2003 | 07:27 AM
Community Builder
Default Re: how to tell if fuel pump is going out? (JimBlake)
well I put my interior back in and I don't hear anything now. I guess it was normal.
jlong17crx
Dec 20, 2007 09:08 AM
prestonpark
Mar 15, 2006 09:45 PM
Eluzion
Apr 11, 2004 09:51 PM
Herminator
Mar 14, 2002 05:27 PM
