Engine Cooling Fan Question....Both Needed???
Old Mar 21, 2003 | 05:18 AM
slow02ss camaro's Avatar
Default Engine Cooling Fan Question....Both Needed???
There are two fans on the radiator....well the one to the driver's side is hitting the turbo....i could trim it put just curious, do the both work at the same time or is one for something else??? The one to the passenger side looks bigger and better and I was wondering if the one to the driver's side is jsut for a/c or somethin???
Old Mar 21, 2003 | 06:19 AM
Stew Pidasso's Avatar
Default Re: Engine Cooling Fan Question....Both Needed??? (slow94accord)
I think you can get away with just one. I'm not sure but the other one may just be for A/C. I 've seen Accords with one only, let's just put it that way.
Old Mar 21, 2003 | 01:30 PM
Chiovnidca's Avatar
It needs both fans for the a/c to work properly. If you get rid of the a/c, one should be fine.
Old Mar 21, 2003 | 11:57 PM
Jago's Avatar
The one on the driver side is the condenser fan.
the other one is the radiator. You could probably
pull the condenser and be fine.
Old Mar 22, 2003 | 04:40 PM
rrei's Avatar
Default Re: Engine Cooling Fan Question....Both Needed??? (Jago)
in the summer you will need both, i had this same problem with my turbo. in the end i bought a motorcycle fan and replaced it with that. when its 90 degrees and up and u boost ur car will over heat. until it cools. this is only if u r not on a highway or something
Old Mar 22, 2003 | 04:46 PM
Nick M's Avatar
Default Re: Engine Cooling Fan Question....Both Needed??? (rrei)
you dont need both in the summer
unless like you said you are running a turbo setup then it would be necessary
elliascool
Jul 18, 2011 03:02 PM
dirty_sancho
May 12, 2010 07:36 AM
redboost10
Feb 15, 2010 07:24 AM
ImPuLsIvE
Jan 18, 2010 03:37 AM
B16CRXT
Jan 1, 2008 08:54 AM
