Identifying a Type R Tranny
well first of all the US had no 99 type R. so most likely its not.
check and see if it has LSD. if you can see strait through the axles then its LSD
there are also some other stuff which ill let the real type R owners tell you so i dont say the wrong things
[Modified by baonest, 1:39 AM 3/21/2003]
(Edited....)
As for LSD, it can always be put in. Get a GSR tranny and put in ITR LSD
and you can see straight thr the axle hole. And they both read "S80" on
the serial code so it makes it harder to tell. Another
[Modified by s2geezy, 3:47 AM 3/23/2003]
j4d lsd
There is no way to tell exactly what year it is visually with out opening it up. By opening the tranny up you can tell if its a 98-01 JDM ITR tranny but not specifically a 99. Once you open it up you can count the teeth. The main will have 14 and the counter will have 67. If it is a USDM tranny or 98+ CTR or below 98 JDM ITR then it will have 15 teeth on the main and 66 on the counter.
