Pics of Integras with Silverstars!!
Im going to buy a set tomorrow and I know some people here use the 9005 conversion!! my question is has there been any problems with the high beam bulb in the low beam socket???..Also does anyone have pics of the 9006 silverstars??..
thnx
thnx
https://honda-tech.com/zerothread?id=310232
https://honda-tech.com/zerothread?id=397024
There are many additional relevant threads to be found by searching "9005" in the Archives.
[Modified by Padawan, 11:16 PM 3/20/2003]
I hear from many h-t members that they blow very often...that is why I would not recommend them although I have no first had experience with them.
They work nicely as is, Silverstars are probably the best bulb replacement upgrade you can get. I wouldn't bother with the whole 9005 conversion junk. Just put the bulbs where they are supposed to go. I like mine alot, and don't have to be worried about melting my harness like with the cheap 80W bulbs.
i use them in the high beams. I don't use them enough to worry about them dying anytime soon and I kinda messed up one of the stock ones (for the record, glass tubes do break when you drop **** on them
hehe)
hehe)
don't know about it but good luck, i bought my low beam lights for 20 bucks, and using it since i got my car, it's been 2 years already , working good
so sometimes cheap stuffs work too
i just put those on my civic... they look too yellow to me and close to stock color. i wish they had just a slight blue color.. although the beam pattern does seam to spread out better then stock
waste of $$$ imho, but to each his own.
