ECU code 14.....IAC bad? How do I check it?
Old Mar 20, 2003 | 03:07 PM
intekragsr's Avatar
Default ECU code 14.....IAC bad? How do I check it?
My check engine light went on and I am wondering if thats the reason my idle is messed up on cold start.
After I rev up and let it warm up, it gets a little better. Once warm, when I rev in neutral, sometimes it drops VERY low.
The light went away, but came back once, and now its gone. ???? but my idle still sucks
Any input?
Old Mar 20, 2003 | 03:17 PM
ajchen's Avatar
Default Re: ECU code 14.....IAC bad? How do I check it? (intekragsr)
could be:
1) vacuum leak due to a disconnected hose or cracked intake manifold gasket
2) bad IACV
3) dirty IACV
4) bad FICV
test all these. my IACV code came because my IM gasket was cracked and it was taking too much air in and forcing the engine to run rich.
if you dont find a gasket leak, take off your IACV, spray brake cleaner on it and wash it off and try again.
Old Mar 20, 2003 | 04:00 PM
intekragsr's Avatar
Default Re: ECU code 14.....IAC bad? How do I check it? (ajchen)
cool thanks. what is the FIAC???
Old May 22, 2003 | 03:32 AM
mskibbz-T's Avatar
Fast Idle Control Valve
4DoorBanger
Jan 15, 2013 10:42 PM
88si
16
Jul 16, 2010 03:20 PM
rush3969
Mar 16, 2006 05:40 AM
benhatch101
Nov 11, 2004 09:54 PM
Prevail
Feb 28, 2003 07:19 AM
