difference between b20 and b18
Old Mar 20, 2003 | 12:41 PM
willywood16's Avatar
Default difference between b20 and b18
well i heard it is a good idea to put a b20 block with a ls head well what is the difference between a ls block and a b20 crv block? thanks
Old Mar 20, 2003 | 12:48 PM
BabyDaddy's Avatar
Default Re: difference between b20 and b18 (willywood16)
bore size = bigger displacement = more torque
Old Mar 20, 2003 | 02:50 PM
Katman's Avatar
They're essentially the same block with about only 2 differences.
The B20 its built upon the B18B block. All Honda did was change the sleeves out to accept a wider piston and added a wider piston. Everything else (rods + crank) are LS spec. Even the head is the same, all you need to do is replace the B20 intake manifold in favor for an LS or skunk2 manifold and its ready for a civic/integra chassis.
Old Mar 20, 2003 | 08:30 PM
StorminMatt's Avatar
Default Re: difference between b20 and b18 (Katman)
There is one other difference between the B18A/B18B and B20 block. And that is the oil breather. It is on the back of the block on the B18A/B18B but in the valve cover on the B20. As for the head, only the B18B has the same head as the B20. The B18A head is different. The intake ports are smaller.
jdmme09
Feb 8, 2009 03:08 PM
NA JDM GSR
May 15, 2006 01:21 PM
PrOjEcTpImPcIvIc
Nov 12, 2003 07:08 AM
88civicHB703
Jul 8, 2003 06:45 PM
CheezeFrog
Sep 24, 2002 04:46 AM
