cel 23, only at high rpms
Old Mar 20, 2003 | 11:44 AM
fastludeh22's Avatar
Default cel 23, only at high rpms
knock sensor. the cel only flashes when i hit the high rpms, 7500 or so, then i t come s on and goes off as soon as i shift.
is it seein knock, or is the sensor going bad?
Old Mar 20, 2003 | 12:13 PM
Sticky Tires's Avatar
* B A N N E D *
Default Re: cel 23, only at high rpms (fastludeh22)
http://www.hondaprelude.to/main_checkengine.html#codes
Old Mar 20, 2003 | 12:48 PM
RAB's Avatar
RAB
Default Re: cel 23, only at high rpms (Sticky Tires)
He knows its code 23 and providing that website doesn't help, it only gives vauge probably causes. Here's real help, here's the problem flow chart.
Old Mar 20, 2003 | 02:29 PM
sharkcohen's Avatar
And just so it is clear, code 23 occurs when there is a problem with either the knock sensor or the circuit. It does not come on when the sensor picks up knock and the ecu pulls timing in response.
Old Mar 21, 2003 | 04:53 AM
Default Re: cel 23, only at high rpms (sharkcohen)
thanks, im going to try that. any ideas why it only happens at high rpms?
robbys89
Apr 10, 2010 01:48 PM
Kangolbrand
Aug 23, 2006 09:23 PM
oranginal
Jul 6, 2006 02:17 PM
hybrider
Feb 21, 2003 09:50 PM
