help with piston ring size
Old Mar 20, 2003 | 08:28 AM
Quetzolcotl's Avatar
Default help with piston ring size
got block honed at domestic shop. they didn't know what the bore was other than the stock listed at 75mm. they said I should use stock rings and that if it was off it would only be maybe a few thousandths, which is a lot with honda engines. can I determine what piston ring size I should order based on piston to wall clearance, or stock piston ring gap size? I have feeler gages but no bore gage. any thoughts or will stock size be alright? thanks
Old Mar 20, 2003 | 08:50 AM
IN VTEC's Avatar
Default Re: help with piston ring size (Quetzolcotl)
Check piston ring end gaps.
xasiansupermanx
Dec 10, 2007 02:06 PM
GreenR
Jan 29, 2003 03:39 AM
98civicEX
Jun 26, 2002 07:43 AM
