opinions.... whats the BEST A/C compatible H22 turbo manifold???
Guest
Posts: n/a
i am trying to sell some stuff and basically start over on my turbo setup, i was thinking of one of the Camp1320 manifolds, but not sure if i can still run A/C.... anyone have any ideas??
and, yes, i am a *****, and am not willing to ditch A/C in both of my cars
As far as I know and have read the spark manifold that camp sells allows you to retain a/c and power sterring. Let me know your findings on this I am looking for something that lets me retain ps and ac in my accord. I have not had much luck finding a decent manifold that lets me keep both, yet.
UPDATE: Just looked at his site and saw the manifold I think you are refering too. I sent him an im asking who makes it and cost and if it allows you to retain ps and ac. Maybe he will see this thread and let us know.
This has been a good success...You probably already looked at it-
It keeps A/C and power steering.
Made 257whp at only 6.5psi on a completely stock motor. If you rev it another 500rpm it will probably put down 275 at the same psi. If you are adventurous, crank it up to 9-10psi and it will put down around 300-325whp which is among the elite as far as power production on completely stock motor(for its psi levels and turbo used)...
Unfortunately, the intercooler piping and intercooler doesn't come with it, that was all custom done in shop here at Super T Motorsports...
Any 4G Prelude applications? (That's on a 97+ Lude, right?)
BTW, I don't know about that BOV venting right into the coil. Heat kills.
Underhood temps often reach 150+ degrees...
The air coming out of the bov comes from the intercooler and we are seeing temps of 70-90 degrees coming out of the bov which cools the coil...
Dave
I forgot to mention I am looking for a manifold to do all of these things with equeall length runners and be tublar as well. That mani looks nice but it doest fit the profile of what I am wanting. Of course what I am looking for coudl be the proverbial holly grail that doesnt exist.
[Modified by KCHybrid, 12:03 PM 3/21/2003]
Guest
Posts: n/a
Turbo is a garret t3/t4 57 or 60 trim .63 A/R
Manifold will be of 321 stainless steel by super t motorsports
downpipe is also made in house at super t and is made of 304...
hope that helps...
dave
hope that helps...
dave
i have been talking to one of my friends about getting one, he swears to me that he can make one if i can't find one.... if he can make me one, i'll have him make 2
Please do
Here is what Camp1320 had to say, sounds like I may have found my manifold. Just worried about all the talk of it cracking.
[Modified by KCHybrid, 9:15 PM 3/23/2003]
(8:48 AM 3/21/2003) KCHybrid: I was wondering who makes the H22 Stainless Steel Equal-length Manifold that you have listed on your site. Also what is the cost of it? From the looks of it, it appears to have a 40mm wastegate flange as well is this true? Thanks in advance for any help.
(8:50 AM 3/21/2003) KCHybrid: Also does this allow you to keep ac and ps?
(7:41 PM 3/23/2003) camp1320.com: SPARK racing makes it but im out of stock... and so are they..i will have them ready hopefully very soon... it should have been done but i have no responce yet
with my rev hard i can keep everythign and run a 3 inch downpipe. but its not equal length..
the drag 3 clears the a/c but its aweful close, I boosted on a long highway run once and cracked the a/c line-hose from all the heat ...
Greg
Greg
i have a spark manifold on a 4g...u can check out my pics on my cardomain...and i still have my ac and power steering...
hrrrmmm I am no engenering major but prehaps why it does have a some what bad rep? Some one want to make one in 321 riping off the design?
Cant belive I just said that...
there are alot of locals here in cali whos manifold has not cracked. maybe due to weahterand air/fuel ratio but im sure alot has cracked and alot has NOT. If the manifold is braced it sould not crack. also if the air/fuel is correct it wont heat up as bad as the IDIOTS who lean the motor out and streess cracks appear. Im no enginnering major either but im sure Camp will give you a great deal and if you are local he will weld up any of his crack manifold for FREE.so far he has not welded up any that he has sold so..?? hope that tells you something. also if you are worried about cracking manifolds get a CAST manifold ask Camp he has those as well.
if you dont have AC and you are willing to run a civic radiator, check this out:
http://www.full-race.com/proracehseries/
otherwise, we are building a tubular that lets you retain the other stuff, but wastgate placement becomes much less than optimal. If it were up to me i would lose the a/c and run a civic rad.
vietdragontekx
Oct 19, 2007 01:54 PM
hondaracin24
Feb 21, 2007 01:03 PM
h22turbolude
Dec 26, 2003 01:54 PM
